Old 12-29-2008, 08:25 PM   #1
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
it was under the sunglasses holder tray.. or my pen and deodorant compartment
i every yaris has the in the cabin one that you called type b .. there should be a diagram of the location in the manual .. i forget which it was but ifound it right away in the manual.. or just take the plate off the fuse box and it says what each fuse does
Old 12-30-2008, 12:53 AM   #2
PatrickJohnson
Drives: 2008 Yaris LB
i found it. basically, there is one panel right behind the sunglass holder, and then if you get underneath the dash to see the underside of that panel, you will see the panel i needed. there are basically 3 fuse panels (at least in the 08 LB):
1) engine compartment next to the battery
2) behind the sunglass holder (pull it out)
3) under the dash directly under the sunglass holder
PatrickJohnson is offline   Reply With Quote
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
blowing ear drums and poping fuses BlueFlash Southwest 5 05-29-2007 07:10 PM
Blitz air filter replacement yrsdrgn Performance Modifications 2 03-08-2007 07:25 PM
