#1 | |
Unless your Malfunction Indicator Light was on as well, you won't see a stored DTC. The TPWS and ABS ECU's have their own reporting over the CAN bus, typically accessed with the Toyota TechStream tool. You can get the TPWS ECU to report its error via flashes of the ! light. See the following post for how to make it do so: http://www.yarisworld.com/forums/sho...8&postcount=11 |
#2 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
The "!" I was refering to was the parking brake light, not the TPWS since I don't have that on my car (2007 model, year before we got them in Canada). It could be because the lights are no longer lit on my dash so it's not giving me any codes. So the Scanguage is the way to go if you want to read stored codes? |
#3 | |
Unless the MIL light was lit, you still wouldn't have logged any codes. I don't believe that the brake system has any DTC's that will be reported on the OBDII. The Scanguage is a great code reader/resetter and is quite a bit more, hence its price tag. If you are just looking to occasionally read and reset codes I would go with a cheaper device, or just go to your local auto parts store - Most will read and reset for free. |
generic code scanners will read powertrain and network codes, P or U codes for our cars from the PCM but to read any body or chasis codes, B or C codes from any other modules you will need a scanner that has CAN compliant toyota enhanced software. without spending big $ you wont get that software easily.
also even if the light already turned off there will still be a history code stored for some time. but without the right software you will never be able to get those codes from any module besides the PCM Last edited by seth_man; 01-01-2009 at 08:30 PM. |
#5 | |
| readers out there??? | joey1320 | Off-topic / Other Cars / Everything else Discussions | 37 | 05-25-2007 04:33 PM |
| Japanese readers, please check this | eTiMaGo | Photo-Video-Media Gallery | 4 | 04-26-2007 07:59 PM |
