Old 01-01-2009, 05:25 AM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I guess I dont understand what this is supposed to do, tighten your rear brakes to take stress from the fronts?
Old 01-01-2009, 05:55 AM   #2
auxmike
auxmike's Avatar
Yessir, distribute the weight so as to not prematurely wear out pads or warp rotors.
This can be tricky to do for a first timer. Don't screw around with brakes unless you are real confident about what you are getting into.
I did this procedure myself after noticing my handbrake lever going up real high when pulled. As he said, go from the FRONT to adjust not from the rubber plug in the back. That way you'll know right away if the shoes are too open since the drum won't slide on.
I used compressed air to remove all the dust eaisily without wetting anything at all. You should NOT use compressed air because that dust is BAD and gets into your nostrils real easy. I only did it because I was outside in the open air.
After the adjustment the brakes felt much better.
I know these cars are supposed to have self adjusting brakes, but I've yet to see one of those systems that works as allegedly designed without a little "help" from a screwdriver.....
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 09:24 AM
Yaris/Echo Rear Brake Question pdarnell DIY / Maintenance / Service 2 08-21-2007 02:15 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 09:47 AM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
