Old 01-02-2009, 01:08 PM   #1
nemelek
DWEED
nemelek's Avatar
If it money that you want to save, DYI is the way to go. I use Castrol GTS that I bought on sale at Checker for $0.99/ quart and filter bought on sale at Toyota for $3.95. Each oil change costs me $8. Using a non-synthetic oil, I'll still get 200,000 miles. Check your engine air filter and tire presure while you are at it.
There is a great thread on making your own cabin air filter. This will cost you less than a dollar each.
Old 01-02-2009, 04:11 PM   #2
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
I use Mobil 5W30 synthetic with a Mobil oil filter. I change every 5000 miles. I put a toyota cabin air filter in to catch anything before it gets to the fan.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 01-02-2009, 10:50 PM   #3
b_hickman11
Drives: 08 Sedan
Actually the filter is after the fan.....
Old 01-03-2009, 04:08 AM   #4
auxmike
auxmike's Avatar
Funny, I had no trouble fitting the cabin air filter in. Got mine right at PepBoys (Purolator). I don't see how Toyota would think it does'nt fit with the "frame" or whatever.
I think it was just a cost saving measure and that most owners would never think to even check for this filter, instead just get it "changed" at the dealer during service for about $59.
As for oil filters, go on Ebay and pick up a case of 10 Genuine Toyota oil filters for about $40. Buy any synthetic, they are all fine, IMHO.
Remember, the car's body will probably rust out before the engine goes either way.......
Old 01-03-2009, 05:14 AM   #5
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
It's done. Changed the oil using Mobil 1 synthetic with filter, then went to dealer to pick up a cabin filter. Local parts stores didn't have it in stock, and they would've had to order it from the dealer anyway. Installing it was way easier than first thought, since it was so floppy and bendable.
Next up is rotating the tires and seeing if I can re-tighten the e-brake without breaking anything
Thanks for all the tips guys
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 11:27 AM
Results from 100,000 maintenance Nigal DIY / Maintenance / Service 22 11-26-2008 12:41 AM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
how much does the first maintenance service cost hans_fh DIY / Maintenance / Service 25 07-05-2007 10:01 AM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 06:13 AM
