![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
i could tell you if it fit if you post a engine bay pic.
because honestly i dont see toyota wasting money making two sepperat engines, rather just one the 1.3, and displacing it to a 1.5. but post a pic to confirm anyway.
Two Yari on home! ![]() |
Ok.Here is a picture
And another one.Imagine it without the blue tube
![]() ![]() Drives: MK I Vitz 1.0l F Package Join Date: Jun 2006
No, the 1.5 engine is a 1NZ-FE, your one the mounting point for the filter is on the top of the engine block
it might work... you might have to work with the intake for a while, i could add some extra straight pieces which might help the fit.
Does it have any adapter for the AFM?
We just have to make sure that it will fit, with the necessary adjustments!
afm?
Oh it is a device after the air filter box, that ''reads'' the incoming air quantity and with the help of the central chip adjusts the engine function.
Your engine should have this.
#9 | |
#10 | |
AFM= Air Fuel Meter. In any case, we are talking about the same thing here.
#11 | |
der Zeck
Air Fuel Meter is another name for an up steam O2 sensor
![]() Drives: 07 yaris MT Join Date: Aug 2006
I don't know why you would try to sell a intake that does not work well in the yaris.
Yes it makes it loud if you can keep the engine running. I tried a set-up just like that, made from the exact the same pieces and it did not work. I wasted more than $80.00 just to try it. The car would not idle correctly and when I gave it a little gas it would just die. Most intakes made for the 1.5 are closer to a 2" diameter. The 3" diameter does not work well with the 1.5l. Maybe it did work for you but doubt it. I just took the loss and tossed the pieces. |
#13 | |
worked fine with the wifes she had no problems with it, she only complained once and I explained to her that it was only because the car had not fully warmed up enough. you might have ran to big of a filter, i chose the smallest most restrictive, so that there would be suction created verses too much air for the MAF sensor to notice. It was a bit bumpy at first but her ECU learned to drive with it after about two weeks. Did you try resetting your ECU after install? the major reason Im selling it is that she complained it was too loud. So i promised her that i would get her another made of smaller tubing to reduce resonation. so we bought the silver AEM CAI, she wants it for her birthday so its not going to be installed until november, and she wont let me open it because she paid more for it than I did, so dont ridicule and flame me for no pics just yet. But after hearing the sound clip for the TRD CAI i think she might end up not liking this one either.
Bummer man
ONE LOVE...YARiS LOVE!!!
does it fit a sedan?
3" diameter?
i went to use a 2.5" diameter intake from my xrs and it didnt work...threw system lean codes stock 1nzfe intake tubing is 2.25"....thats what the maf is set up for frankly, im surprised that intake runs w/o cel's, funny idle, or odd power peaks mid-range.....
#17 | ||
From Yaris Repair manual Engine control page ES-1 |
Holy dragged up dead post batman!!!!!
| AEM INTAKE ***UPDATE*** | riceboy | Performance Modifications | 30 | 09-10-2007 07:35 PM |
| Air selection intake broken? | David81 | General Yaris / Vitz Discussion | 16 | 06-29-2006 02:51 PM |
| K&N Is looking for 2007 Yaris for Intake Development. | Knfilters | Performance Modifications | 9 | 06-28-2006 04:34 PM |
| K&N Developing intake | mykole | Performance Modifications | 9 | 06-22-2006 01:34 AM |
| Cold Air Intake ? | pegcityrs | Performance Modifications | 47 | 04-17-2006 07:43 AM |
