Old 01-03-2009, 09:28 PM   #1
Chupacabra
Drives: 2009 Yaris liftback
MT-90'd the gearbox today...
I replaced my gearbox fluid with Redline MT-90 today. It was simple...required no jacking of the car and the quantity was exactly 2 quarts. My impressions after a short drive is that...it's not much different but certainly noticeable. All gears appear a touch easier to engage, most of all first, second and reverse. Overall, a good modification for $25.
Chupacabra is offline   Reply With Quote
Old 01-03-2009, 09:43 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
good job :D
and that's only 9more dollars than typical gear oil.. i run lucas 80W90 with no issues either.. then again i AM on trans#3 lol
Old 01-03-2009, 11:15 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I'm lovin the MT-90 also...
PetersRedYaris is offline   Reply With Quote
Old 01-03-2009, 11:30 PM   #4
at3GG
at3GG's Avatar
Drives: 07 metmet LB
Using Royal Purple here...also just slightly noticeable, but definately smoother
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 01-04-2009, 06:42 AM   #5
gid
Drives: '08 Yaris sedan , '08 Liftback
MT-90 working its magic so far . Better cold shifting and no clunk into reverse . Found that when 1st made the switch to MT-90 that it's good to work through all the gears and gets bit better over time .
gid is offline   Reply With Quote
Old 01-04-2009, 02:43 PM   #6
Chupacabra
Originally Posted by gid View Post
MT-90 working its magic so far . Better cold shifting and no clunk into reverse . Found that when 1 st switch to MT-90 it's good to work through all the gears and gets bit better over time .
Awesome...I figured it'd only get better as I went for a short ride.
Old 01-04-2009, 04:36 PM   #7
gid
Thumbs up enjoy ...
let us know if the shifting improves and the clunk into reverse gets less or goes away over a period of time .
Old 01-04-2009, 04:38 PM   #8
gid
I would like to try the AMSOIL MTG ( GL-4 , 75w-90 ) in the future .
Old 01-04-2009, 08:57 PM   #9
Chupacabra
Actually went for a drive today and noticed that the shifting is much improved. Much smoother shifts and the reverse clunk is gone. It just seems to slide right into reverse now.
Old 01-05-2009, 05:44 AM   #10
gid
praise the bottle of REDLINE MT-90 . You'll find frigid morning shifts to be easier than the stock gear oil and gets smoother much sooner than the conventional . No grinding when downshifting , especially down to 1st . . Enjoy
Old 01-06-2009, 09:06 AM   #11
Chupacabra
I have never downshifted into first gear but I wanted to update this thread because the difference in the gearbox is worth ranting about. By switching to the MT-90....shifting if phenomenal. I can't stress enough how good of an upgrade this is. Reverse is butter and so are all the other gears. It just seems to get better every time I drive.
Old 01-06-2009, 01:11 PM   #12
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i got amsoil for months now but i havent put it in yet...too lazy..
Old 01-06-2009, 01:19 PM   #13
Chupacabra
Get it in there....the difference is amazing and you'll thank yourself for it.
Old 01-06-2009, 02:07 PM   #14
gid
I changed it with another dose of the MT-90 at 10,000 miles as a flush , that way would be all synthetic . Probably change it again at 60,000 miles or so . That may be the AMSOIL MTG , also GL-4 and 75w-90 .
Old 01-06-2009, 03:18 PM   #15
marcus
toyota
marcus's Avatar
i will...this weekend..
by the way im not liking the mobil1 synthetic on my engine.. tracking mpg and still showing it dropped down switching over..never gonna use mobil1 ever again..
Old 01-06-2009, 05:18 PM   #16
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im a mobil one user since 1000 miles. what are you gonna use next as im open foe something new......
Old 01-06-2009, 05:22 PM   #17
marcus
toyota
marcus's Avatar
amsoil... a lot less detergents use compare to mobil1...also higher flash point as well..
Old 08-06-2009, 10:33 AM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Just curious which Amsoil and Mobil 1 products you are referring to and why you believe Amsoil is less detergent?
TIA
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Look what just came in the mail today!! PETERPOOP Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 10-21-2008 09:34 PM
Where is my oil leak coming from? The Gearbox? MarkBond General Yaris / Vitz Discussion 1 08-25-2007 10:31 PM
Finally ordered my new rims today! Thanks for all the help thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-03-2007 06:37 PM
Got my second door ding today! bugnuts General Yaris / Vitz Discussion 5 03-14-2007 10:07 AM
Placed my order today drdavidr4u New YARIS Purchase Forum 8 06-19-2006 03:43 PM
