Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
Hey all,
I have my car scheduled for it oil change for Monday morning. My shifting has gotten really rough and hard to put into gears. I told the guy last time but he basically ignored it. Now it's worse... so I made sure when I called them that they completely understood that there is an issue with my shifting and I want it fixed. I also mentioned the guy dismissing it the previous time. So I really don't know a WHOLE lot about cars... enough to get around. From this thread, I gather that the gear box has separate oil that needs to be changed to keep shifting smooth? Should I mention this to them? But I don't want to say anything if I don't know what I'm talking about...
#2 | |
Drives: 2009 Yaris liftback Join Date: Nov 2008
#3 | |
DIY, it's a no brainer / five minute job. I recall seeing a step-by-step process posted here somewhere. The stealership will charge a fortune. An independant garage less perhaps but still not worth the time and expense.
Yaris = <3
Ok, that definitely is a good idea. You really can't tell parked putting it from gear to gear after the first one. But when you're driving... it's not very nice. Thanks! =)
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
since you're in frigid north the gear oil thickens making for poor shifting , etc.. If possible get 2 quarts of 75w-90 GL-4 synthetic gear oil such as REDLINE MT-90 ( http://www.redlineoil.com/products_g...7;categoryID=7 , < than $14 a qt. ) , AMSOIL MTG , www.amsoil.com/storefront/mtg.aspx , < than $14 a qt. ) or PENNZOIL GL-4 synthetic ( http://www.pennzoil.com/products/gea...#SyntheticGear , < than $12 a qt. (?)) you'll notice a big difference on those very cold days . The REDLINE and AMSOIL gear oils are a true synthetic , the PENNZOIL is not . Try to stay away from GL-5 gear oil , it'll make your driving experience even less pleasing . Know this for a fact when used MOBIL 1 GL-5 synthetic gear oil in a 2000 Chevy PRIZM ( Corolla ) . I have the MT-90 in our '08 L.B. and shifts are quite easy when car has been sitting in temps of 25 degrees or less . The switch to synthetic is well worth the money . Let us know how it works out . GOOD LUCK
![]() ![]() Drives: Yaris Sol 1.3 dual VVTi 101hp Join Date: Apr 2009
switched here too to MT-90, simply it's a MUST with all croppy Valeo shift
Yaris Sol 1.33 dual VVTi model 09 - 5dr 1. full ZX1 additive treatment: oil + cooler + fuel 2. NB treatment: motor oil 3. K&N panel air filter (part num. 33-2211) 4. Fuchs Silkolene Pro SRG 75 gear oil (the best!) 5. UltraRacing 19mm rear sway bar |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
As gid says the Yaris MT calls for a GL-4 gear oil-DO NOT use a GL-5 as it can affect performance or even be damaging to any soft metals in the tranny. The metals in some GL-4 applications don't like the high levels of sulfur that is used to give some GL-5 lubes their extreme pressure properties. The sulfur is what gives gear lubes their signature odor.
R2 |
R2,
Not pertinent to your question above but I switched to Redline MT-90 and have drained the box twice as to get all synthetic in there. WOW....what a difference shifting is with this stuff. It shifts like butter.... Car only has 5,900 miles on it so....I'll probably change the gearbox fluid again at 15K miles just for ha ha's.....then let it go for a while. |
Crazy Oil Sniffer
DerFlosser,
Yes Redline's gear/transmission lubes are widely liked and respected-I don't doubt for a second they are a noticeable upgrade. The MT-90 is GL-4 so your good to go. Your plan sounds like a good one-I usually do similar on new transmissions and differentials to get to break in metals flushed out. R2 |
I love momentum.
How much does the tranny take? I've changed tranny fluid in other cars and I'm used to the "fill it on level ground until it drains out the fill hole"
#11 | |
Audio Junky
I've been contemplating doing the fluid switch myself.... i'm at 32k miles... maybe i'll do it next summer when i'm around 50k. |
I love momentum.
Can anyone fill me in (pun intended) on how much fluid to use? I know the shop manual specifies an amount (1.7quarts?), but is it the kind where you have to pour in the perfect amount, or the kind where you pour in fluid until it leaks out the fill hole?
Thanks! |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
I wish I could buy MT-90 locally!
Cant get that mess anywhere in or around Collingwood where I live in Canada!Apparently some shops in Toronto sell it, but its 2-2.5 hours south of me... and its simply not worth the drive down to the city in $$ and time just to pick up some gear oil If i get some, ill hafta wait till im down there anyways and make a detour on the way home to try and purchase it. Or i can order it online off Amazon.COM for $11 US a quart... but shipping to Canada is fucking $15-20... and ill bet ill be hit with stupid duty too... adding another ~ $10 to the cost... Not sure its worth it to try to score this redline gear oil for my car with another 20-30 bucks added to the cost!? What do yall think? Worth it even at around $50 for 2 quarts ???
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#14 | |
#15 | |
Once I put conventional transmission oil in my ECHO. Worked great in the summer. When winter came on a cold morning it would barely shift gears until you drove like 5 miles! I had the guy add some more food coloring (orange I think) and NO PROBLEM! |
TRIM HUNTER
i did my trans fluid swap last year sometime. how often should i be changing this?
I do it about every 10/15k miles, generally I try to do it together with motor oil change, keep in mind that I use the car at 99% in urban streets, probably making a sort of 50:50 (between city & highway) you can retard the change
Is everyone here using a manual tranny?
Im on an automatic, and I was wondering how to change the tranny oil out. Got her since day one, and the car has around 54k miles on it now. Want to change the tranny oil to the best that I can put in there (since an extra $1-3 a quart really isn't a big deal). Is there a DIY for this? Thanks.... |
| Look what just came in the mail today!! | PETERPOOP | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 10-21-2008 09:34 PM |
| Where is my oil leak coming from? The Gearbox? | MarkBond | General Yaris / Vitz Discussion | 1 | 08-25-2007 10:31 PM |
| Finally ordered my new rims today! Thanks for all the help | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 06-03-2007 06:37 PM |
| Got my second door ding today! | bugnuts | General Yaris / Vitz Discussion | 5 | 03-14-2007 10:07 AM |
| Placed my order today | drdavidr4u | New YARIS Purchase Forum | 8 | 06-19-2006 03:43 PM |
