Old 01-05-2009, 01:19 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by kou View Post
the only reason i ask is i am planning on getting the zage turbo kit,once the RH intake manifold comes out and thinking an extra injector may be best to turn on when needed instead of having the bigger injectors on all the time.
i don't think you understand how injectors work.. and considering you can get tC injectors for free generally, it's a win/win
Old 01-05-2009, 04:52 PM   #2
kou
Drives: 08 lb
whats to understand an injector turns on and off if you have a bigger one it releases more fuel.so a free cold start injector from an older VW would probaly work better to turn on when needed than four bigger injectors running all the time.
Old 01-05-2009, 06:03 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
larger injectors open for less time... it's called duty cycle.. you can run 550cc injectors as long as your pulse width is short enough
Longest time you left your Yaris engine running iwantayarisnyc General Yaris / Vitz Discussion 35 12-17-2008 10:07 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
