Old 01-14-2009, 09:32 PM   #1
rkvin21
Drives: 2012 Toyota Yaris SE
I just installed my underdrive pulley and water pulley. Unfortunately I didn't install the alt because it was getting dark and I didn't know how I should go about replacing it. Do I have to remove the alt? If so how do I go about that exactly. I can loosen all the bolts no problem but what about the cables that are connected to it?
Thanks in advance
rkvin21 is offline   Reply With Quote
Old 01-14-2009, 09:39 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Thanks in advance
if you can loosen the mounting bolts you can loosen the cables ;)
it may be difficult to get the alternator pulley off without an impact gun though..
Originally Posted by xnamerxx
you nailed it sir.
Old 01-14-2009, 09:43 PM   #3
rkvin21
So are ur saying I should pull it forward or take it off? I have an air ratchet does that count?
Old 01-14-2009, 10:10 PM   #4
when we do the pulley installs, I take the alternator off, it just makes everything easier.
Old 01-14-2009, 10:16 PM   #5
rkvin21
i kinda figured I would lol. I'm still asking what is the best way to remove the cables that are connected to the alt more specifically the lower one. Is only brute force the answer to unplugging it or is there another way?
Old 01-09-2009, 10:46 AM   #6
The "troll" just bought a set of pulleys, so before you all go off flaming the crap out of him (which you already did), maybe CONSIDER that he's trying to get educated, wants his car to be faster, and isn't just trying to get a rise out of you.
"peg leg"? wow.
No grace at all - if this board turns into another ScionLife, I'm out.
yeah guys, there's no proof at all that this guy is who you think he is, so let's all chill out, ok?
Old 01-12-2009, 09:40 PM   #7
rkvin21
Thank you
Use 14 wheels ( 185-55 r-14 will shave almost a sec off your 0-60 RIGHT NOW.
After doing research on this theory. It is not necessarily the size of the wheels that makes the car quicker but the ratio of the tire ie 185/60 vs 185/50 the 50 being quicker. Although if you do keep the same ratio of the same width but drop size you theoretically will but just by dropping the ratio by 10 will improve more revs per mile. Also what I have learned about doing this mod to get quicker will reduce your top speed also affecting your accuracy of your speedometer. This is the Calculator I used.
I just got my pulleys in the mail(a slip anyways). The lazy....ya..... didn't even come to my house to do a deleivery and just put the slip in my mailbox. So tomorrow i'm gonna pick them up. Don't know when i'll get to install it but i'll let you guys know what I think when I do. Thanks Garm!
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
Mods on an automatic sedan? naix Performance Modifications 19 12-10-2009 11:30 AM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
**CUSCO Type OS strut bars** C2AUTOSPL Sponsors Classifieds Area 12 08-04-2006 11:35 AM
