Old 03-13-2006, 05:31 PM   #1
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Originally Posted by SmellyTofu
You'd probably find it's a wire switching thing and also a "local" North American specifications as the European and Japanese standard for lighting does not require low beam to be on with the fog lights. High beam though should turn off fog lights (ECE regulation) but whether or not this actually happens differs from country to country specifications.
Btw, it's not any unsafer to drive with fogs only in thick fog. Low beam just makes things worse for the driver in fog as there is too much light reflected back from the near-side cut off which is higher than the off-side.
yeah, that's why I'm asking if there is a way to get around having fog light on only when low beam is on...
GabL is offline   Reply With Quote
Day time Running light....how to disable? Polar_Yaris DIY / Maintenance / Service 33 01-27-2009 06:02 PM
