Old 01-09-2009, 01:13 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by jkuchta View Post
On mine with an Amsoil filter I'd say its a pretty standard number of turns (like 2-3 full turns to contact,and then another 1/3-1/2 to snug).
Thanks. I know the Denso filters tave the base plate hole threads start just about even with the base whereas other filters are down 1/8- 3/16" depending on how the base plate is designed ( punched) and how thick the gasket is. I will say the "o-ring" style gasket onb the denso is a good feature - the filter can lip limits the gasket crush and helps prevent leaks (I just had to say _something_ good after trashing the Thailand made toyota (denso) the past few ... I plan to try the denso again next OCI - now what syn to use ... oh my brain hurts !!
TheSilkySmooth is offline   Reply With Quote
Old 01-09-2009, 02:13 PM   #2
1stToyota
1stToyota's Avatar
This isn't very scientific, but I still have an AMSOIL Ea filter and the PureONE. Side-by-side the AMSOIL's base plate hole appears to be recessed down slightly more than the PureONE's, and the AMSOIL's hole is the thickness of about 3 threads, and PureONE's is about 4 threads thick.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 01-11-2009, 09:53 AM   #3
TheSilkySmooth
Thank you for the feed back, 1stT. I have a metrology lab where I work - I'll bring in a denso Yzzf2, a Wix and NAPA pro-select and measure them. It will not include gasket crush, but Ill see whtas going on. I know the yzzf2 thread is very close to the gasket surface (may the data gods confirm my eyeball). -Bro
