Old 01-13-2009, 12:27 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i dont get high flow oil filter.... isnt it high flow less dirt thats being filtered..dont get it.
Old 01-13-2009, 12:32 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
not necessarily. a "larger" filter is a higher flow filter because it's less restrictive.. with the same dirt holding properties..
but the lower the restriction the lower overall oil pressure you'll see.. by 1-2 psi.. not a big deal honestly, especially when you're running heavier oil in a forced induction application
Old 01-13-2009, 01:08 PM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Just a couple thoughts:
If the oil pump doesnt have an internal bypass relief, then the pump will force the filter to pass whatever it can pump - which means if the filter media is overwhelmed, the pressure will unseat the bypass valve in the filtercan, and NOW you got plenty of flow (though unfiltered). Hey, I suppose it doesn't have to be constantly filtered. Understand, on most cold starts under 20 deg F the filter is not working at all - its just bypassing until the oil warms up. The "gelled" oil just wont flow through the media. - the bro
TheSilkySmooth is offline   Reply With Quote
Motor Oil and filters Lafiro DIY / Maintenance / Service 94 03-15-2010 03:40 PM
FS AEM CAI w/dry flow instead of oil filter superfly78209 Items for Sale by private party 24 12-26-2008 10:43 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 10:51 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
