Old 01-16-2009, 11:21 AM   #1
hi/low....in canada we need day time running lights so i figure ..during the day keep it on high beam which will shut off the fogs..then set it it low at night plus fogs hid..= brightness.. good luck!
just disable the drls...if you dont have factory fogs, just pull the drl module, thats what i did
Old 01-16-2009, 11:25 AM   #2
33OH
Drives: '08 Yaris
Same here. Takes 5 minutes.
Old 01-16-2009, 12:57 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well i would but i have fogs and i got hids on them...cant lose that..plus i dont want hid running during daytime....
Old 01-16-2009, 02:08 PM   #4
so you have an RS? then just cut the power wire to the DRL's (i did that on my XRS) and install a switch for them...
Old 01-16-2009, 08:29 PM   #5
RSboyz
RSboyz's Avatar
so you must disable DRL with either bi-xenon or hi/lo beam HID installed on car? when i get my HID, im thinking of switching the DRL to my fog lights. is that possible? im probably gonna go to a shop and get everything done, not sure how much it would cost. any idea?
RSboyz is offline   Reply With Quote
Old 01-18-2009, 09:34 AM   #6
marcus
toyota
marcus's Avatar
you can switch wire fr drl to low beam just remember not to flash ur high beam cos i think if shuts off the fogs when you do that..rule #one you cannot have hid going on and off due to the ignite..
Old 01-18-2009, 10:47 PM   #7
RSboyz
RSboyz's Avatar
im currently running PIAA extreme white halogen right now and i think it does an adequate job, but i think because my parking light is still the stock halogen bulb, so it makes the PIAA not as bright. Thinking of changing the parking light to LED since there are so many restrictions with HID.
xenon hid light bulb lilman717 Cosmetic Modifications (Exterior/Interior) 7 12-19-2008 08:07 PM
Hi & Lo Beam HID Conversion Kit OgDogg Items for Sale by private party 0 11-11-2008 04:55 PM
HID HI/LO Bulbs & Ballasts 8000K FOR SALE never used OgDogg Items for Sale by private party 6 09-16-2007 01:52 PM
HID Kit XENON Brand Yaris-TJ Cosmetic Modifications (Exterior/Interior) 18 10-27-2006 09:46 AM
