#19 |
GreenRanger
Drives: 08 Yaris sedan Join Date: Jan 2009
Thank you Bailout. Yeah that's what I usually do, I switch it to neutral when I come close to a light and I always thought it's good because when you brake, it's not fighting against the engine when you are on D.
#20 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
coasting from 50 or so to a light while shifting from drive to neutral affects gear mesh. essentially will strip clutch packs and teeth... |
#21 |
GreenRanger
Hmmm I don't switch on 50. More like in the 20-35. Sometimes I caught myself close to the 40 mark. Is that still bad?
#22 |
I'm no trans expert. I'll wait for someone to answer your question with more knowledge....
#23 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
With DFCO, why are you shifting into neutral? There is no gas being delivered anyway...
#24 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
You should stay in D and coast when coming to a stop so your engine is slowing you down and you can benefit from DFCO, where as long as the rpms are above 1200 or so, fuel to the engine is cut off and you're using no gas. DFCO is best in all circumstances unless it greatly shortens the length of your coast. There's one spot I can coast in N for 3 kms some days, but in D I could only coast for 1/2 a km. In those cases I think it's best to coast in N for a long distance and use less fuel, than coast in D for a short distance and use no fuel. |
#25 | |
GreenRanger
I read the DFCO thread, I don't quite understand how to do it. So I leave it in D and just release the gas pedal and let the engine automatically slow down on its own? I have an Automatic so I dunno. Sorry I'm new to cars. |
| Paddle Shifting (for MT) | Tamago | Performance Modifications | 95 | 01-31-2014 08:19 AM |
| Sqweek while shifting (MANUAL) | dallas | DIY / Maintenance / Service | 43 | 09-01-2010 04:57 PM |
| Didn't buy; awkward shifting? | drmitch | New YARIS Purchase Forum | 89 | 03-03-2009 10:44 AM |
| Yaris Auto Transmission shifting | g man | Canada | 9 | 08-23-2007 01:16 PM |
| Shifting (A/T) | daq421 | General Yaris / Vitz Discussion | 54 | 04-03-2007 01:30 PM |
