Old 01-17-2009, 01:32 PM   #1
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
Side marker LED lights
I installed these and love 'em. Here's a few pics. The connector on the right is the connector on your smoked leds'. It needs to plug into the connector on the left which is from the wiring harness inside the fender well. You'll have to slightly modify your connector on the smoked led lights. I used a dremmel tool to cut away the shroud exposing the pins. and they plugged right in to the wiring harness connector. I used some electrical tape to hold them together. Remember there is polarity here.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 01-21-2009, 02:13 PM   #2
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Are those the smoked or clear?? They look great!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
Fog Lights - only right hand side JayCee Cosmetic Modifications (Exterior/Interior) 3 09-26-2006 05:44 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
