Old 01-19-2009, 10:49 PM   #1
ddongbap
Originally Posted by ROCKLAND TOYOTA View Post
any other mods on car? with the sway bar and gt spec braces my rear doesn't surprise me anymore unless i come into a turn a little too fast......
Bald tires, sagging springs, uh... lightened rear end? Jk.
I do carry a lot of speed in my corners at the.. track.
But a sway bar, that'll just be exaggerated under my normal entry speed, and it'll kick out at lower speeds, right? I'm not 100% sure how these solid rear beams work 100%.
BTW, putting a sway bar induces under steer in the front, and over steer in the rear. I think.
Old 01-20-2009, 04:23 AM   #2
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
it reduces body roll and neutralizes steering
this is of course dependant how big your front and rear sway bars are to eachother.
I was running a 22mm front sway bar with a 22mm usdm type r sway bar on my old integra and it handled beautifully but it would really kick out and give me some good throttle lift oversteer if i wasnt careful
overall, sway bars are usually the best suspension mod in my book so i will definitely be buying one in the future
by the way, does anyone know how large the front yaris sway bar is and how large the trd rear sway is? im curious
Old 01-20-2009, 11:49 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I believe the TRD Rear is 22mm.
I don't know about the front. I don't feel a need to change it anyway.
Old 01-20-2009, 11:48 AM   #4
largeorangefont
Break'em off some.
Put a rear bar on. The car will feel more planted and you will be able to carry more speed though a corner. I've noticed it actually keeps the entire car flatter through a corner.
It absolutely DOES NOT induce front understeer, it reduces front understeer.
Old 01-20-2009, 04:45 PM   #5
ddongbap
ahh ok. this is the first fwd im trying to upgrade. not 100% sure about solid rear physics on these.
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 02:52 PM
TRD Parts Install Cost lactosedude Performance Modifications 8 09-22-2007 01:49 AM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
Woof's Big Rear Sway Saga..... woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-03-2007 12:24 AM
NF210 versus TRD springs nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 04-01-2007 05:30 PM
