I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I'm curious what octane you guys are using... I've been putting premium in mine, because the difference in a 10 gallon tank is only about $2-$3 extra per fill up and in our yari, that's not that often... Seems to have better pickup and mileage. What do you guys think?
#2 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
If you drive it like you stole it you will see a slight increase in MPG with higher octane fuel but if you drive lighter or are a hypermiler you will see a large decrease in MPG with higher octane fuel.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
In full summer set up i was getting close to 800 kilometers per tank,now with winter tires,and winter formulated gas and only city driving i'm lucky to get 400kms,as for using higher octane gas in a car meant for regular gas?an absurd waste of money.
toyota
ok i dont get how ur losing half of ur mpg... i guess im not doing too bad with 500km on a 36 liters./ 7 bars this winter 60/40 cty/hwy.
I might be able to get it up to 500kms but that would be getting into the flashing last bar for sure.
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Don't use premium unless the vehicle's computer was tuned to run *Premium fuel only* at the factory. |
your computer will adjust the timing as close to pre dentanation as it can with the fuel you have in the car.test have proven the fact that any car will produce less power with regular than with premium.
![]() ![]() Drives: 07 Yaris LB, 93 Camaro Join Date: Aug 2007
who did this "test"? I'd be interested in seeing it
-Aaron ![]() |
I ♥ Yaris
Yea, me too... My informal tests (I.E. how it feels to drive and mileage per tank) seem to show better power and mpg...
It's a proven fact that Ford TSB's had to be released because they figured out that long cranking times during startup was because owners used premium in cars designed to burn 87 octane. Talking about effecency, not power.
what does ford have to do with anything.
if you have upgraded your car with performance parts and drive like you stole you will get pinging at higher rpm's and full throttle with 87 octane.if you drive like a grandma and your car does'nt get past 3500rpms use 87 octane all you want.toyota recommend 87 octane yes, but with a high compression motor and high rpms i would not use it. even the smart car recommends premium knowing you will get pinging with regular.
#13 | ||
first time i heard that one......Quote:
#14 | |
#15 |
Yeah, I forgot that Ford builds cars that have ignition systems, internal combustion motors, A/F ratios, burntimes, etc, that are exactly opposite of how every other automaker builds their cars now.
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 10:07 AM |
| Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 08:24 AM |
| ACEITES Y MANTENIMIENTOS | Yaris PTY-507 | Central and South America | 22 | 10-01-2007 10:57 AM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
| Tired of poor gas mileage & buying premium gas. | Boosted Peon | New YARIS Purchase Forum | 29 | 08-25-2006 08:59 PM |
