Old 01-23-2009, 10:43 AM   #19
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
the theory behind the hot wires performance is that they are not just a spark plug wire. You can theoretically hook a normal spark plug wire to the ignition coils if you really wanted but I would agree that this would be a complete waste of time. The hotwires have a capacitor built into wire thats where they claim to have a benefit.
Tehxfallen. Don't lose complete interest. Some manufacturer make upgraded replacement coils for cars, that require no aftermarket stand alone. Spitfire makes them for a lot of nissan applications, and there is another company whose name escapes me. Not all coils are created equal, which is why you need a standalone if you are going to drastically change the characteristics of the coil. Otherwise, your ecu would control the different ignition coil sporadically.
http://www.hotrod.com/techarticles/i...ech/index.html
This is a helpful article, althought it is about v-8s with a distributor and all, it begins to explain the ignition system in a little more detail, so you can start to comprehend what it is that you need to consider.
turboyaris is offline   Reply With Quote
final installation of nology hotwires turboyaris Performance Modifications 28 05-14-2015 01:17 PM
