Old 01-24-2009, 01:56 PM   #1
charles nelson
Drives: red Liftback
Connecting wiring to small trailer
I have a Class I trailer hitch on my 2008 LB, which I have used for a two bicycle carrier. I need to pull a very light weight trailer to haul
six bikes. Total weight is less than 300lbs (tongue weight about 30lbs)
I need to connect Yaris wiring to trailer.
Which type of trailer wiring rig do I need?
There seem to be three options.
1) directly tap into the rear light wire loom for each trailer light
2) use a trailer converter module which gets its 12VDC from the rear wires
3) use a trailer converter module which has to have a new 12VDC power
wire run up to the battery
I don't want to damage any auto-electronics...
charles nelson is offline   Reply With Quote
Old 01-24-2009, 06:04 PM   #2
yarstar
Drives: 2008 Absolute Red HB
Man, I can't help you with the wiring, but I would LOVE IT if you would post some pics of the bike trailer you are talking about. I use a hitch rack for mine, but when I got to race, I sometimes need to carry 4 bikes (2 road/ 2 TT) and it's a bit much for my rack, so I was interested in getting a trailer and doing what you are talking about. I'd be really interested in seeing what your setup looks like. PM me or post some on this thread if you wouldn't mind. It would really help me out making my decison. I'll be watching this thread also to see what resolution there is for the wiring. Good luck with that.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 01-24-2009, 10:25 PM   #3
#2 - You will need a converter to "merge" the turn and tail lights if your trailer has a standard 4 pin harness. You don't need the #3 style converter, as the Yaris's lighting uses simple relay based switching.
Old 08-01-2009, 07:25 AM   #4
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
So something like this will not work? Autozone Harness
Also, does anyone have the color codes for a liftback?
Old 08-01-2009, 09:17 AM   #5
No, you would need this type, as you need to combine the tail, stop and turn lights together for the 4 pin trailer harness.
http://www.autozone.com/autozone/cat...questid=108197
For 07-08
On the taillight connectors (J3-Right, J4-Left):
Stop: J3,J4 - Pin5 (purple-LH side, orange-RH side)
Tail: J3,J4 - Pin 4 (green-LH side, gray-RH side)
Reverse: J3,J4-Pin1 (red LH-side, brown-RH side)
Ground: J3,J4-Pin6 (white w/black stripe)
Turn-Left: J4-Pin3-LH (green)
Turn-Right: J3-Pin3-RH (yellow)
For 09:
On the taillight connectors (J34-Right, J35-Left):
Stop: J34,J35 - Pin1 (purple-LH side, orange-RH side)
Tail: J34,J35 - Pin 4 (green-LH side, gray-RH side)
Reverse: J34,J35-Pin5 (red LH-side, brown-RH side)
Ground: J34,J35-Pin6 (white w/black stripe)
Turn-Left: J35-Pin2-LH (green)
Turn-Right: J34-Pin2-RH (yellow)
Old 08-01-2009, 08:58 PM   #6
Sodium Duck
╚══════════RN
Bueno, mucho gracias!
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
hitch wiring hell twixt DIY / Maintenance / Service 9 06-02-2007 12:27 AM
Small Shift knob H8SGAS Items for Sale by private party 3 09-25-2006 07:28 PM
