Old 01-25-2009, 10:18 AM   #1
Originally Posted by AlexNet0 View Post
how did you apply the gasket maker? To the Manifold side or the TB side?
im pretty sure i put it on the throttle body
to be honest, i wouldnt being doing this in the cold....im not sure how the gasket maker will set up when its as cold as it is right now....
when i did mine it was in sept of 2008....so it wasnt too cold yet
but for the record you SHOULD be disconnecting the battery when you swap tb's....itll reset the ecu so the car can relearn on the new tb. let it idle for about 10min and then youre off. also, not a mod id keep on the car in winter due to the high idle when the engine is cold...
Old 01-25-2009, 07:15 PM   #2
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I still have 1zz and still oscilates, its and Iddle malfunction. I have installed the stock one a few times and you HAVE to disconect the batery and before the installation of any of the TB. And as thebarber said it take about 10 min for the car to iddle rigth after you put the 1zz TB.
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
