Old 01-26-2009, 07:25 AM   #1
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
I am a little confused the spacer i have goes between the drum and the wheel and the ones in the pics are behind the drum
the studs i need to remove are different
i understand needing to knock them out but it looks like once loose i still wouldnt be able to back them out because the drum cluster wouldnt be deep enough to get them out
am i not understanding how you get the studs out?
Old 01-26-2009, 08:50 PM   #2
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Then maybe you can't do this job yourself. You will need to disassemble the brake assembly if you cannot pull the studs out, and only then can you knock them out. Go borrow a slide hammer.
anonymous user is offline   Reply With Quote
extended warranty... yes/no? TinyGiant General Yaris / Vitz Discussion 42 09-01-2009 01:43 PM
Extended Service Packages Shadowbeast New YARIS Purchase Forum 1 01-16-2009 11:30 PM
Found a good deal on extended warranty Bretsuaz New YARIS Purchase Forum 1 05-02-2007 10:40 PM
Extended warranty worth it? oni5000 New YARIS Purchase Forum 17 09-04-2006 04:19 PM
Extended Service warranties! Buckethead New YARIS Purchase Forum 31 07-29-2006 07:46 PM
