I don't think anyone was putting down the idea... maybe just offering some oppinions on the mod. For one, I would never install Wilwoods on any of my cars again, I have them on one of my cars still and they are horrible quality, need rebuilds all the time and there are very few decent street pad options.
If you have your heart set on big brakes I would consider the bolt on kits from Endless, Project U, and Brembo first. Also there is a good chance the Stoptech and Rotora/Megan will offer kits in the near future which will be priced more competetively. |
#2 | |
Like I said, just trying to get conversation flowing. Its what I do... having said that, I still think FWD owners that cram every inch of Brembo they can on their two front rotors screams rice. Now all of you converse wildly about the JDM rear brake install while I sit in my office chair while laughing like Dr. Claw. Last edited by ChinoCharles; 09-07-2006 at 11:34 AM. |
Actually, after putting my rims on today, I really do want rotors not aswell. These drums just aren't that good looking, but thank god they are atleast black!
#4 | |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
well other than performance, it just looks too damn good!!
Honda Convert
Drives: NCP91L Join Date: Sep 2006
There's nothing wrong with having a bbk on the front and drums in the back. With a car this light, this short and very front-heavy, it makes more sense than putting discs in the back, even if that were an easy option for this car, which it isn't.
When Wilwood or some other company releases a rear disc conversion, it's something I'll consider, but don't expect major braking performance coming from the back of this car. |
#7 | |
If you thinking about putting battery to the back and make it weight balanced. That mean RICE. (it does nothing good to a FWD car) Weight balance only apply to RWD cars. Also adding weight to suspension component is adding your unsprung weight, just like getting a heavy wheel. That will reduce your performance i.e. mpg, acceleration. |
#8 | |
maintenance of momentum
#9 | |
Moving battery to to back for a FWD doesn't help to to reduce understeer. You just move your weight to the back and make your car more dragging. In order to address nose heavy is to replace with light weight part, but not moving part to rear. |
While I agree that replacing stock parts with lighter weight versions is the preferred method for achieving maximum performance and handling benefits, relocating movable objects within the car to get as close to a 50/50 balance (regardless of drive setup) is also extremely valuable. This decreases the polar moment of inertia of the vehicle, making the car easier to turn and maintain in a neutral behavior throughout the turn.
adding weight to the rear of the vehicle definetely helps! I carry around sand bags when I go around the track
I'm also planning on adding another engine in the rear to drive the rear wheels, and then I'll get 18" wilwood brakes and some chrome exhaust bearings to grease up the flux capacitor
Ecurie Snoopy Lives
Just to update this thread, In the latest Siphon mag there is the Tein Yaris that has the Wilwood brake kit and the rears are basic drums but the car brakes awesome and performs awesome.
The advantage to a rear disc setup is that the drums can overheat and then they don't brake worth crap. I used to have a 69 Firebird convertible with drums on all 4 corners. I can vouch for the reliability of drum brakes. There's alot more out there available for brake kits on the market now. If you don't do performance/track driving a steel line setup and better pads are all you need. But otherwise they do look better. 13 inch rotors are probably overkill, but they're available out there for our cars. JBT has them availalabe now, 4 pot system. I think they are working on a rear disc system as well.
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
![]() ![]() ![]() ![]() Drives: 240sx, 00 Celica Join Date: Apr 2006
LIke i said on the other post, Greddy also makes BBK for the Yaris.
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL 24711 Redlands Blvd., Ste. I Loma Linda, CA 92354 T: 909-796-8189 E-mail: info@c2auto.com AIM: wide180sx |
Wilwood makes nice stuff. My brother builds and competes professional rockcrawlers and they use it on all their trucks. If it can lock a 38 inch tire mounted on a bead locked wheel filled with water for extra low end weight, it could stop a Yaris FAST.
a big brake kit front and rear would be really nice on this car :p
Ecurie Snoopy Lives
I've seen a Wilwood rear disc kit on an xb and it looked great!
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: May 2007
Get your Yaris to the track with some DOT -R Tires and chase around Evo's and Porsches and you will be clamoring for a big brake kit, esp. with a turbo kit. I got the DEZOD pads and they never seemed to get the "bite" other listers seem to rave about. It's perhaps the rotors not being slotted, but at the end of the day I needed more brakes. When I didn't have some jackass in a 350Z laying on the brakes, they were fine on open track... I guess that's the thing I really noticed:
Open track, stock brakes were fine because you were using them about to the limit without having to do any exaggerated braking. In traffic, I had did not have the stopping power (remember, the DOT-R tires are WAY grippier so the car stopped pretty fast, but not repeatedly). Anyhow, I know it's easy to poo poo people who want bigger brakes, but when you get to the track and push the car, it becomes absolutely clear what the weaknesses are: HP and Brakes. Luckily I put on the Megan Racing coilovers, they were AWESOME on the track. I think the Wilwood (who have been making brakes for decades and what most Miata's run on the track) are inexpensive, trusted and have excellent support. I will post a separate thread about the Yaris at the track.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass! Many thanks to our sponsors: Weapon-R http://weapon-r.com Megan Racing http://www.meganracing.com Les Schwab Tires http://www.lesschwab.com 317 graphics http://www.317graphics.com Last edited by Vanderkitten; 06-16-2007 at 06:45 PM. Reason: IN ALL FAIRNESS |
resident senior
My brakes have turned a pretty shade of blue before . Was able to light a cigarette off them before also . They do have tendancy to get mushy . I have ordered SS lines(back ordered) and plan on changing the fluid . Has anybody tried the E-bay drilled rotors ? Know where I can get drilled rotors ? Decent Pads ? I do 1 track weekend , 1 Dragon trip and 1 Autox every month . Sometimes more .
| Brake Shopping | drell42 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-12-2007 12:25 AM |
| cheap trd big brake kit *joke* | birdy | Off-topic / Other Cars / Everything else Discussions | 3 | 06-13-2006 12:04 AM |
