Old 01-26-2009, 10:58 AM   #1
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
depending on your suspension you may rub with the +38mm offset.
a 7" +25mm rear is a pretty good look with some camber and coilovers though. :)
I think the 15mm would be too much though.
although you should look into hubspacers instead of "wheel" spacers.
Russelt3hPirate is offline   Reply With Quote
Old 01-26-2009, 04:23 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks for your help!
I have NF210 springs riding on stock shocks. So far I have absolutely no rubbing (not even with the car full) and I want to keep it that way.
The spacers that I linked to are hubcentric BTW.
Old 01-27-2009, 05:03 AM   #3
ddongbap
I don't get it, whats the difference between a 25mm, and a 38mm with a 10mm spacer?
Thats only a 3mm difference.
Old 01-27-2009, 10:18 AM   #4
Russelt3hPirate
l33t3st Asshole
3mm is alot when we're talking wheels and tires.
a 48mm might fit but i doubt a 51mm would.
even a 45mm to a 48mm.
it isn't alot when you're in the appropriate range but once you're on the outside edge or inside edge of the range 3mm can mean the difference between rubbing and fitting perfect.
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
