Old 01-26-2009, 04:26 PM   #1
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
hubcentric and hubspacer are two different things.
hubspacer mounts between the hub and the axle spacing the hub 10mm (therefore also the wheel).
a wheel spacer (hubcentric or not) will space out the wheel only.
how are you doing on space between the tire and the fender at full compression?
with our setup at +25mm it's very close to hitting the fender and it does on a rare occasion depending on the severity of the bump.
Russelt3hPirate is offline   Reply With Quote
Old 01-26-2009, 04:33 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Really? Didn't know that...
I haven't really measured, but something close to an inch. I think I should be fine with 10mm... I'll make some real measurements and post up though.
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
