Old 01-27-2009, 02:15 PM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by Chupacabra View Post
I am not small and no you don't need ramps (DF210's). Oil filter simply comes off with a set of channel lock pliers...then re-installation is just hand tight. No tools required aside from the 14mm box end for the drain plug. Now that I have the fujitomo valve...I do oil changes with no tools at all. Quick and simple.
Interesting,
could you explain a little bit more "fujitomo valve"?
Thanks
CLA 250, 4MATIC
Old 01-27-2009, 02:22 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interesting,
Thanks
http://www.fumotovalve.com/
Old 01-27-2009, 02:28 PM   #3
MadMax
MadMax's Avatar
Moved the thumbs-up smilie over as it was embedded within the URL...
Cheers! M2
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Super Amazing Oil Change DIY id3379 DIY / Maintenance / Service 34 11-28-2008 01:20 PM
DIY - oil change kurokoma-kun DIY / Maintenance / Service 7 11-20-2008 12:12 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
