Old 01-28-2009, 12:12 PM   #1
33OH
Drives: '08 Yaris
Correctamundo.
Well, I'd like to do the same thing. Is there a certain spot you'd recommend cutting it at? Or anything you would do different?
33OH is offline
Old 01-28-2009, 12:17 PM   #2
ChinoCharles
Drives: LB
I would have cut it down a little less. I'd recommend nothing more than an inch and a half. Cut it from the middle of the shaft. We cut 2 inches off of mine, and then I sat in the car and held the top piece to the bottom at an angle where it felt comfortable and we welded it on that way, so my shifter is kind of custom fit. It pitches toward the rear of the car a little bit. Feels great. If you're going to go that route, make sure the top piece is long enough so the stock shift knob will clear without hitting the angle.
ChinoCharles is offline
