Old 01-29-2009, 01:04 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Yawesh View Post
just curious, if let's say i got aftermarket headers, catback, etc. would they still honor warranty(and if VIN shows up)
i think if you sat down and thought about it.... you'd answer your question.
if you remove the stock header, and put on an aftermarket one, do you think toyota would provide you a warranty for your aftermarket part?
also, you will void your o2 sensor warranty with aftermarket parts.
Old 01-29-2009, 01:24 PM   #2
yaris-?
yaris-?'s Avatar
Drives: 2000 Civic
agreed, dealerships love aftermarket parts cause they can always blame your mods if need be
yaris-? is offline   Reply With Quote
Old 01-29-2009, 01:24 PM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
then it really blows for ppl that modded the yaris
Yawesh is offline   Reply With Quote
Old 01-29-2009, 01:28 PM   #4
MadMax
MadMax's Avatar
Yeah, but you can't expect dealers to replace something that you've already replaced! About the only way they'll do that is if you had to fix it prior to the recall/TSB. But you'd have to have records showing that the item that was identified in the recall/TSB had failed, not that you simply decided to swap/mod it out yourself!
Cheers! M2
Old 01-29-2009, 01:54 PM   #5
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Cheers! M2
true, unless you work for a dealer and can get away with it......
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
