Old 01-29-2009, 03:04 PM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
if the struts need "slotting" what does that mean? Would that cost extra?
Old 01-29-2009, 04:06 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I believe that just means ovalizing out the holes in the struts where the factory camber bolts are placed. This allows for more movement and more adjustability in terms of camber while not having to buy new camber bolts. If done correctly it is a perfectly acceptable way to overcome the camber adjustment issue. In addition, struts are wear replacment items, so they're going to get replaced in the future anyway...
PetersRedYaris is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
URGENT help needed :( -DIY springs Masteraal DIY / Maintenance / Service 19 12-23-2008 03:23 AM
Who makes camber bolts? largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-08-2007 12:22 AM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
