Old 01-29-2009, 05:27 PM   #1
ddongbap
Having slight camber doesn't ruin your tread life. It will be probably only a smidge shorter.
Old 01-29-2009, 05:31 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
agreed. if you rotate, or even flip, your tires regularly you'll be fine
what kills tires is excessive toe
remember, folks, because you have trailing arm suspension in the rear, any "built in" camber set by the factory (and believe me, there's built in camber) is turned into "toe in" when you've lowered your car. lowering a trailing arm suspended car almost always leads to more understeer then you experienced pre-lowering. a swaybar can help trick the rear into rotating, but the best thing you can do for the rear end of a yaris after lowering is to get shims to correct that excessive toe-in created by lowering.
Old 01-31-2009, 11:33 PM   #3
phenoyz
phenoyz's Avatar
Drives: yaris
shims
planning to lower my car...plan to get springs and sway bar
what is SHIMS? do i need that too
thx
phenoyz is offline   Reply With Quote
Old 02-01-2009, 12:19 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
thx
shims mount between your axle and hub. most alignment shops have them. they're unfortunately usually made from plastic though.
i corrected by putting a stainless washer between the hub and axle, installed on the lower "front" bolt. i'm currently running about 1/16" of toe OUT in the rear. the washer thickness was .058.
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
URGENT help needed :( -DIY springs Masteraal DIY / Maintenance / Service 19 12-23-2008 03:23 AM
Who makes camber bolts? largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-08-2007 12:22 AM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
