#1 | |
what kills tires is excessive toe remember, folks, because you have trailing arm suspension in the rear, any "built in" camber set by the factory (and believe me, there's built in camber) is turned into "toe in" when you've lowered your car. lowering a trailing arm suspended car almost always leads to more understeer then you experienced pre-lowering. a swaybar can help trick the rear into rotating, but the best thing you can do for the rear end of a yaris after lowering is to get shims to correct that excessive toe-in created by lowering.
#2 | |
![]() ![]() Drives: yaris Join Date: Oct 2008
shims
planning to lower my car...plan to get springs and sway bar what is SHIMS? do i need that too thx
#3 | |
i corrected by putting a stainless washer between the hub and axle, installed on the lower "front" bolt. i'm currently running about 1/16" of toe OUT in the rear. the washer thickness was .058.
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| Adjustable Camber Bolts | cali yaris | Micro Image | 30 | 12-11-2009 09:38 AM |
| URGENT help needed :( -DIY springs | Masteraal | DIY / Maintenance / Service | 19 | 12-23-2008 03:23 AM |
| Who makes camber bolts? | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 07-08-2007 12:22 AM |
| Is it practical to install stiffer shocks without also installing lowering springs? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-18-2007 01:23 PM |
