Old 01-29-2009, 07:07 PM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
more likely you forgot to hook something back up.... check all your connections and look for a loose ground
Old 01-29-2009, 07:32 PM   #2
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
It's only a negative battery terminal, 2 plugs on the alt., and a ground on the alt. Pretty sure they are all connected...I'll double check. I don't know why ALL of those fuses would blow.
cm07yaris is offline   Reply With Quote
