#8 | |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
You would need the headlight stalk and relay. I paid $76 for the stalk. http://www.trademotion.com/partlocat...07&catalogid=2 Then, to get the fog light indicator to light up on the instrument cluster and close off the circuit in the fuse box, the relay is needed and its $20. http://www.trademotion.com/partlocat...07&catalogid=2 Using the stalk is the simplest way, and factory plug and play method to install the fog lights. You don't have to go through your firewall, and no dismantling of your interior is needed. You will have to remove the steering wheel, which is quite an easy task, and also remove your front bumper which is also quite easy. You also do not have to splice any wires at all. You basically run the wires to each bulb housing, then that same harness branches off to a battery grounding, and to 2 connectors in the engine fuse box. Really easy, and far better than the DIY parking brake button switch method. Best of all, the stalk contains the switch for the fogs right where you switch on your headlights and turn signals. Once setup, the fogs turn on when the headlights are on (not the daylight running lights), switch off when highbeams are used, and turn off when the car is turned off. You can also choose to switch them off at anytime. I can also send you a Toyota PDF manual/schematic on how to install the fog lights, as per factory recommendations. |
| 2008 Yaris Fog install | ReMiX | Cosmetic Modifications (Exterior/Interior) | 8 | 12-19-2008 12:30 PM |
| Yaris 04 HB Fog lights (1st Generation) | Rudysin507 | Central and South America | 3 | 12-17-2008 10:43 AM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
