Old 03-16-2009, 02:35 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I'll try to do a better job next time. Thanks.
No problem, you just have a like a 30 # boost gauge
Old 03-16-2009, 10:41 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I was seeing ign timing dropping to single digits under boost this evening.
Old 03-17-2009, 12:05 PM   #3
largeorangefont
Break'em off some.
Yea, the car is fine then... Don't loose any sleep over it.
Old 03-17-2009, 02:36 PM   #4
kurokoma-kun
Drives: 2007 Yaris HB
Lieutenant, your readings indicate a warp core breach is imminent... you've got to shut down the reactor now, then run a level 3 diagnostic on the matter/antimatter reaction control system
sorry Long, not to make light of your concerns, I've just been wanting to say that to you for some time and now seemed like the right moment
Old 03-17-2009, 02:47 PM   #5
See Long, and you make fun of me when I speak Klingon
Old 03-17-2009, 02:20 AM   #6
rpalai
Drives: 2008 NEW Yaris 2-door Liftback
I have to agree with the comments posted by most of the members. Slightly larger injectors, or is there any way of possibly increasing fuel pressure to the injectors under boost to a higher level than the controller is allowing? Perhaps an Apexi-II unit or something similar that can work alongside the Blitz fuel controller? This lean condition is a real concern and has to be fixed! If it is happening in your car, it most likely is happening to everyone who has this system installed, like me! This will probably be an interesting and do-able fix, hopefully. Thanks! RPALAI
rpalai is offline   Reply With Quote
Old 03-17-2009, 02:27 AM   #7
would be pretty easy to throw a set of Scion tC injectors (about a hundred bucks on eBay) and see what happens.
Old 03-17-2009, 12:06 PM   #8
largeorangefont
Break'em off some.
That would be the worst thing he could do at this point. If he is seeing single digits for timing under load, he does not want to add more fuel.
Old 03-17-2009, 03:06 PM   #9
LtNoogie
LtNoogie's Avatar
I tried to make a video last night while driving and hand holding the camera. Not recommended. I'll install the camera mount tonight and shoot another video.
Old 03-18-2009, 09:32 AM   #10
LtNoogie
LtNoogie's Avatar
The video was too shaky to post.
Old 03-17-2009, 08:42 PM   #11
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I'd like to chime in with my a/f readings, but I don't got a wideband a/f gauge yet. However, it is true that I have not experienced pre-ignition. But, I did put in lucas oil's octane booster with shell's 92 before i got the kit installed and running. I'm not sure if this is preventing the pre-ignition, but I am not experiencing any. I don't know if I don't use the boost octane if I will experience it or not, but I don't plan on not using the boost octane for a long time.
I'm also not experiencing the noise that occurs when the car is in idle and the a/c is on. I don't know if I have a lucky kit, or a newer kit, or what not, but my kit seems to run flawless as of now. We'll see if the story changes once I see my a/f readings.
Old 03-18-2009, 03:54 PM   #12
rpalai
Help!! Having a Blitz-related problem!!
Hello again all! Hope you are all doing well. Unfortunately, I am not! My car ran GREAT from the moment the Blitz system was installed as well as all last night and early this morning until the very last time I started it up, it threw a code and the check engine light came on. When I hook up my scanner, it shows the code as "pending" which probably is why it keeps doing it even after I clear the code with my scanner. Can someone help me with this? Whenever it throws the code, it goes into "limp mode" and becomes rather doggy of course. It is showing code P01387 which means that "voltage too high in 02 sensor 1 Bank 2", or something like that. Now I know that my mechanic told me that he had a problem getting the old 02 sensor out of the factory exhaust header to transfer it over to the new Meagan Racing header, but he WAS able to do it after he had to soak it in a LOT of PV Blaster penetrating oil for awhile. But that was now a couple of days ago and all of the PVBlaster should have burned off the 02 sensor by now, unless perhaps it destroyed it in the process? I can not figure this out. I am really bummed now becuase every time I start the car, it throws the same darned code and goes into limp mode again.
Can anyone please help me with this? Thanks!
Rich
rpalai
Old 03-18-2009, 05:47 PM   #13
kurokoma-kun
Here's what the repair manual has to say about P0138, O2 sensor high voltage:
"...when the air-fuel ratio is richer than the stoichiometric air-fuel level, the oxygen concentration in the exhaust gas becomes lean. The HO2 sensor informs the ECM that the post-TWC air-fuel ratio is rich (high voltage, i.e. more than 0.45 V). The HO2 sensor has the property of changing its output voltage drastically when the air-fuel ratio is close to the stoichiometric level."
So IMO he'll be wanting to pinpoint the cause of the extremely rich air-fuel ratio (injectors, fuel pressure, exhaust leak, etc.) in addition to checking the sensor itself.
You can find the entire Engine Control manual and many others here, hosted by our own etimago --> http://www.etimago.com/yaris/repairmanual/
PS-- you may get better response if you start your own thread for issues like this it's too important to get buried among other info.
Old 03-18-2009, 07:22 PM   #14
largeorangefont
Break'em off some.
Noogie,
What we need you do do is to do a WOT pull to redline from around 2000 RPM in 2nd.
Strap that camera down :)
Again, from the shots you provided I don't think you have anything to worry about.
Old 03-18-2009, 07:43 PM   #15
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
those are about the same readings i get.
if the lights on the gauge read 14ish and the lights around the edges are still in the green then ur mixture is good. right?
Old 03-18-2009, 08:22 PM   #16
largeorangefont
Break'em off some.
Not necessarily. If you timing is in the single digits, then yea it is probably OK. If not, those numbers are not OK.
Old 04-07-2009, 03:15 AM   #17
PETERPOOP
PETERPOOP's Avatar
Noogie,
Did you ever do this?
Old 04-07-2009, 09:45 AM   #18
LtNoogie
LtNoogie's Avatar
No. I'm built a new camera mount but the digital camera died. I'm going to get some data logging software to collect data a little bit better than shaky videos.
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
WTB or free front bumper any condition in SOCal Walter Items for Sale by private party 3 09-14-2007 12:56 AM
