Old 01-31-2009, 06:14 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by PHXDEMON View Post
I would say bigger injectors as a first step. Maybe an upgraded fuel pump as well
fuel pump is fine
bigger injectors would definitely help. source a set from a celica gts or a scion tC (i run tC injectors) you can find them both for cheap (i got mine for free, make friends with a service tech at toyota)
until then, STAY OUT OF BOOST, you're gonna blow your engine running lean like that on boost.
Old 03-15-2009, 09:51 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
fuel pump is fine
I just assumed something the size of a D cell battery would be stressing
Old 03-16-2009, 12:03 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I just watched the Youtube video. It looks too lean under boost, unless the timing has been retarded by the SC adjustment box (which could be the case). The first cat is not falsifying your AFR readings much. Clearly your wideband is very close to accurate because you are seeing 14.6 AFR during cruise.
Only way to tell for sure would be to datalog the timing, or get an EGT gauge, or both. Either way, the car would benefit from a tune, probably in the neighborhood of 15-20 HP.
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
WTB or free front bumper any condition in SOCal Walter Items for Sale by private party 3 09-14-2007 12:56 AM
