What you think
planning on gettint the dc header and the underdrive pulley set think it will net me some good whp numbers? i already have trd exhaust and afe intake but dont really feel a diff
any other performance mods ideas are welcomed
der Zeck
pulley set is very noticeable when installed
yea pulleys are must not sure about the header... lots of info on the subject was lost during the hack cant seem to locate it now :(
it's been posted in the last couple days. people have claimed +3whp with pullies. so, about $100/hp
hhmm ok so no header then. i cant remember once where some1 showed a dyno of header gains(excluding Richards). So is the header just a placebo for our cars?
everything but forced induction and a tune is a placebo on the 1.5L 1NZFE
#8 | |
der Zeck
but a lot of little mods that add a tiny bit of HP all do add up.... don't add up to much, but it does add up
so dc header yes...no?
der Zeck
tell you the truth, I do not think anyone has noticed anything from installing a header... I sure did not
Mr. Clean
I can't comment on the header by itself since I installed my header/cai/exhaust all at the same time, but there is a definite improvement on the top end. 5000 to redline feels much better. It does feel about the same as stock until you get past 3500rpm.
#12 | |
![]() ![]() Drives: 2007 Sedan S Join Date: Oct 2008
I'm not sure why others didn't see this, but I saw a BIG difference when I put on my Weapons R 4-2-1 header. It went like this:
TRD catback = little change AEM CAI = a little change NST Pulley Set = a little more change Weapons R Header = Big change! This was just my experience.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
how hard was the install. I heard the crank pulley is a pain to get off and some guy snapped his header after a couple moths due to a bad install....he forget to install the spring nut thingy..
Header is pretty straightforward, 3 bolt and 2 nuts + the 2 bolts/springs connecting stock manifold to the headpipe. There is also a lower bracket w/1 bolt and a small bracket holding A/F sensor wire. The A/F Sensor will need to be removed from the stock exhaust manifold and installed in the new header. Just a heads up many of us had the "crossthreaded" A/F Sensor and had to buy a new one because the stock one just cannot be removed.
so i goto by more stuff where do i get it? part number?
I bought header from Dan over @ We Sell Car Parts for $265. DC part number THC4407
I also purchased a brand new A/F Sensor from Ken over at Sparks for 170.25, Toyota part # 8946752020. Hope this answers your question |
yea thanks. why they make it crossthreaded? i wonder if it shows in the manual how to get it out. Hard to think they made it so it could not be removed
