Old 02-02-2009, 12:28 AM   #1
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
it is not recommended to be done on a yaris, it was just a test ;D
Its a Chao!!!
Old 02-02-2009, 06:57 AM   #2
dinamix
Drives: magntic grey
is it possible to run these on the rears of my yaris since im not turning on the rears? im on a 1.5 inch drop..
my buddy has a spare set of 255/40/17 laying around in his garage..my wheels are 17x7 offset +42..i was thinking 255/40/17 on the two rears and 205/40/17 on the fronts..I wanna give it the muscle drag car look
dinamix is offline   Reply With Quote
Old 02-02-2009, 07:00 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
if you have ABS i don't recommend running different tire diameters on different ends of the car.
and the rear will take some massaging to make a 255 fit. you'll HAVE to add camber shims. the rear has less clearance than the front (Russeltehpirate, chime in here please)
Old 02-02-2009, 07:39 AM   #4
dinamix
thanks for your help man
yeah..no abs..i have the base model
the camber shims issue is a good point..ill probably be ruining the suspension geometry in the long run..i notice running camber kits/shims is pretty common with the wide wheel slammed vw golf guys..but if the can do it why can"t we?
should i stick to my 205/40's for now?..those A032R's are so damn tempting..
btw those tires look awesome..do you have a side view of the car?..
Light inside Yaris. Twistoffate0817 General Yaris / Vitz Discussion 5 12-28-2008 10:21 AM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
