Old 09-03-2006, 08:10 PM   #1
autophile
Drives: '07 HB Manual Yarrrrris
Door/dome light?
Hi all,
In every single car I've owned, when you open the door, some kind of interior light goes on, either the dome light, or the lights under the rear view mirror. However, it was really disconcerting to find that when I opened the door of my Yaris no interior light came on, which sucks at night.
Is this normal? Or is something messed up?
Thanks,
--Rob
Yarrrrrris!
autophile is offline   Reply With Quote
Old 09-03-2006, 08:13 PM   #2
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
It's probably not normal cause in my 2k2 Echo I have the dome lights who light up when I open my doors.
But in the Echo I can disable this feature by putting the switch to OFF on the dome light.
Check if you have a switch located around your dome light... maybe it was just on OFF.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-03-2006, 09:15 PM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Mine has the power package with keyless entry. If yours is stripped there may be a difference.
When I unlock the doors with the remote, the dome light comes on. If the door is already unlocked and I open it - it comes on too.
This seems pretty obvious but... there is a on/off/door switch on the dome. Do you have yours on door?
Old 09-03-2006, 10:00 PM   #4
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Nope. I have the convenience package and it works fine. Check that the dome light is set to door (in the HB the domelight is just behind the front seats line dead centered and I THINK the switch has to be all the way to the right to be set to door.
TrancosRt is offline   Reply With Quote
Old 09-04-2006, 12:42 AM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
look at the center mounted interior light (not the map lights).
It has a three way switch
ON, DOOR and OFF
Make sure the switch is set to DOOR to activate the interior light when the doors are opened or unlocked.
Old 09-04-2006, 09:50 AM   #6
autophile
Ahhh, I am teh dumb for not even noticing the dome light, let alone the switch on it.
Thanks!
--Rob
Yarrrrrris!
Old 09-04-2006, 10:00 AM   #7
Violin
Violin's Avatar
If you'd just take off that silly pirate eye patch...
Old 09-06-2006, 08:26 AM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
ON, DOOR and OFF
i was just thinking the same thing....if its set on DOOR....LOL!
Old 09-06-2006, 08:51 AM   #9
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Thanks!
--Rob
Time to walk the plank!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 09-06-2006, 09:11 AM   #10
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Old 09-06-2006, 10:37 AM   #11
ChinoCharles
Drives: LB
You're all insane.
Old 09-06-2006, 06:13 PM   #12
dngz
dngz's Avatar
Drives: black yaris sedan
-__-...
dngz is offline   Reply With Quote
Old 09-09-2006, 12:20 PM   #13
fred812
Authorized User
fred812's Avatar
Drives: 2007 5 spd Hatch White
I noticed that we have the theatrical fade on the dome light, on my matrix I had about 10 seconds of dome light, on the yaris about 2-3 seconds. I want to rice it up a bit with blue bulbs and liked that long fade to black effect. is it just mine that responds that quickly? I can modify the discharge timer, to make it fade longer if need be...
fred812 is offline   Reply With Quote
MAINT REQD light PSU Yaris DIY / Maintenance / Service 9 12-24-2008 06:48 PM
Coolant Light Cathy DIY / Maintenance / Service 15 09-04-2006 01:28 AM
yaris digital speedo light up? jamal1984 General Yaris / Vitz Discussion 7 08-27-2006 04:01 AM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 03:20 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 12:26 PM
