Old 02-03-2009, 05:49 PM   #1
Jaminjer
Drives: Sedan
I installed the nf210 on my 08 sedan, it dropped the rear 1.75 inches and 1.2 in the front. the rear drop was more than i wanted but does look good. If you buy lowering springs be sure to ask what the drop is for the sedan as most advertise the drop on the hb and the 2 are definately different.
Jaminjer is offline   Reply With Quote
Old 02-04-2009, 09:55 AM   #2
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Thanks! I end up getting the set of Elibach. It suppose to drop 1" F/ 1" R, so I'm taking in consideration the fact the for the sedan it should be a little more. Hopefully it will be all good!!!!
GioBatera
Giobatera is offline   Reply With Quote
Old 02-04-2009, 01:49 PM   #3
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
You wanted the rear to sit higher than the front? Or is the rear lower than the front now?
ZING is offline   Reply With Quote
Old 02-04-2009, 04:38 PM   #4
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Well, I'll be dropping 1" front and rear. I strongly believe that it's gonna b about 1.3" or so, total
GioBatera
Old 02-04-2009, 07:36 PM   #5
supmet
Drives: 2007 4 Door Yaris
Let us know how they feel and if you rub. I'm probably gonna end up going with the TRD springs on 16s. Are you keeping the rest of the suspension stock?
Old 02-05-2009, 08:27 AM   #6
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Yeah, at least for now...
GioBatera
dropping, lowering car, springs
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Which lowering springs? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-25-2008 12:18 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
