Old 02-04-2009, 05:16 PM   #1
clayky
Drives: '07 Yaris S Sedan
This exact problem happened this time last year to my '07 sedan. It was a bad left rear sensor covered under warranty. Now it's happening again and I'm 2,500 miles outside of the basic warranty (of course). I did however, find a TSB for this very problem for both rear sensors. Something about a corrosion problem. If it's very expensive I'll just hold out for the Civic Si I've had my eye on.
clayky is offline   Reply With Quote
Old 01-16-2010, 10:33 PM   #2
beleza33
Drives: 2007 Toyota Yaris
Word for word the problem you guys are having, I'm currently having. I have a 2007 Yaris that I bought in March of that year. I'm a little over 38,000M and of course I got the basic 36000/3 year warranty. I went to the dealer when my ABS/Brake lights came on and BAM! $600-$650 to fix. I'm getting some second/third opinions on the issue because this is NOT an issue I or ANY person should be having with a car under 3 years old that has reasonable wear. At NO time during the possession of my car was it immersed under water or even in high flood water so this problem is unacceptable. They're going to get SICK of me.
beleza33 is offline   Reply With Quote
Old 01-16-2010, 11:15 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If the hub has to be completly replaced it would take a Toyota Tech no more than 1/2an hour
I say this becuase as a lot of people know ,that have put in Hub spacers
it takes less than that to remove the hub and bolt it back up with the spacer behind it .
as for the part failing at 38,000 miles
In New Zealand standard waranty is 3yr's 100,000KM or gold warranty
5 Yr's 150,000KM
Old 02-08-2010, 10:21 AM   #4
pokoki
Drives: 2007 Yaris type S
Does any one know the TSB # for the rear speed sensors???
pokoki is offline   Reply With Quote
Old 02-08-2010, 10:28 AM   #5
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
T-SB-0120-08 ?
seal allows corrosion on abs sensor
127.0.0.1 is offline   Reply With Quote
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
Speed sensor for navigation install saue1436 In Car Entertainment + Electronics (audio / video / alarm) 5 04-12-2007 09:40 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
