Old 02-04-2009, 08:16 PM   #1
NonStopTuning
Our first shipment of 11 and 15lb batteries came in today. I knew they would be small, but I must admit I was blown away by how small they actually are in person.
They definitely look to be of very high quality and I love the fact that each battery comes with its own tech card, showing size, specs, date on which the battery was manufactured, and CA test results. Each battery also comes with a full one year warranty.
Most of the batteries we received in our first shipment are already spoken for, so I have placed an order for a second shipment, scheduled to arrive Friday.
I would recommend the 11lb to most customers not running extra lighting or stereo components. If you have much of the latter, then you may want to consider stepping up to the 15lb or larger.
MIKE @ NST
www.NonStopTuning.com
Old 10-21-2009, 12:22 AM   #2
advocate
Drives: car
Fog lights and HIDs wouldn't fall into the category of 'extra lighting' if the car came with normal halogens and no fogs right?
Old 10-21-2009, 02:19 AM   #3
NonStopTuning
If your OEM battery is doing OK now in your daily driven car, then the 11lb would be a great fit.
The 15lb would provide you with some excellent weight reduction as well, and would provide that much more peace of mind.
Either option would be a great fit for the Yaris.
MIKE @ NST
Old 10-22-2009, 11:17 PM   #4
NonStopTuning
MIKE @ NST
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... NonStopTuning Performance Modifications 195 12-23-2011 12:44 AM
