Old 02-08-2009, 09:59 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by mimelio View Post
I used Bosch +4 plugs in a friends 2002 Echo and it actually gave it more punch (slightly) and a bit better gas mileage I changed them out for NGK Iridium plugs (on sale with rebate) after 50,000 miles with no problems.
Usually any car will respond to new plugs unless the heat range is way off or the electrode gap is off. One month down the road will tell a bigger tale. The ford dual-ended coil resonant ignition will spark the bosch plug - the toyota tiny coils will be toast. They NEED an easy to spark plug and the Ir fit the bill. Ir with small electrodes is biggest advance in plug design in 100 years. I racing we MADE our own plugs. Big secret - can't say anymore or Dick Childress will kill me ...
TheSilkySmooth is offline   Reply With Quote
Old 02-08-2009, 05:11 PM   #2
mimelio
Drives: NONE
Performance isn't as good with the new Iridium plugs...I have a couple friends one ran his Echo 150,000 miles on +4's and the other over 200,000 on his Tercel with no issues.
mimelio is offline   Reply With Quote
Old 02-08-2009, 05:31 PM   #3
TheSilkySmooth
Whats in there, NGK or Denso Ir? Didnt the Tercel have dual coil ignitor?
Dyno chart or three 1/4mil runs back to back with New Ir vs New Bosch +4? OTW its all seat of the pants. Really I cant complain about seat of the Pants especially if they are size 6 Tight Jeans with holes
BAck to reality, Hey if you want MORE power and you did some mods like CAI and maybe header or fart can: go one Heat range COLDER (like 6 vs 5 in NGK) and file back GND electrode the open the gap another 0.1mm
