Old 02-09-2009, 11:08 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
A lot of this plug non-sense is from aircraft ignition problems and Failsafe engineering. Many non-injected aircraft engines have a lean-rich mixture controller with exhaust heat readout and if you run a lean condition too long you may end up toasting a plug and then toasting yourself a few minutes later (the fall isnt bad its the pavement that hurts the most). The electrode redundancy is to keep you flying ( or on boats to get you to shore) . OTW the less crap shrouding the centre electrode the lower the misfire rate.
TheSilkySmooth is offline   Reply With Quote
