The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
DIY: Braille Battery install
So you bought this fancy, weight reducing, yet powerful battery and now you wonder, how do you install it? Well, if you bought the battery with the mounting kit, then you're in luck. If not, then maybe you can get an idea from my DIY.
TOOLS: - 10 mm wrench - 4 mm allen - 5 mm allen - Phillips screw driver - measuring tape - bottle of beer (preferably New Castle or Blue Moon) The Prelude: This is under the assumption that you have bought the mount kit AND should already know how to assemble it. Now...grab that 10 mm wrench and take off the battery cables and the battery tie down doo-hickey ![]() Grab the plastic battery tray and take a good look at the bottom plate The holes that are identified are where the mounting screws are going to go through ![]() The MAIN course: There are two methods to this. If you have a good eye, you can drill the holes that correspond with the mounting points simply by looking at the bottom of the tray, as there are indention that you can use as markers. The OTHER method involves getting your measuring tape. The FIRST hole measures at 4cm x 15cm. BUT MAKE SURE that the arrow of the battery tray is facing you as seen in the images. ![]() ![]() The second hole measures roughly 9cm x 7cm. ![]() ![]() Almost done: The two holes should measure about 9.5cm from each other. You get the mounting base and two self tapping screws and attach the base to the battery tray. ![]() ![]() Place the battery in the mounting plate ![]() Attach the other washers and screws... ![]() Once done, place the complete battery and all onto the bottom plate. The mounting screws should align with the identified holes. Attach the cables and viola! IF you want some extra security, you COULD attach some nuts to the underside of the bottom plate to secure the battery. ![]() Once all is done, grab that bottle of beer and stare at the awe of your accomplishment. I hope this helps. I still don't have a fool-proof idea for the hood rod. But if I come up with something, y'all be the first to know. |
Thanks for the nice writeup/pics!
★weeaboo★
Why thank-you my good man. I don't really drink much so figured that i'd drink the best whenever I do.
as far as the battery. I do like it. I still think my cold cranks are faster due to the new battery. Besides, a small battery for a small car? Brilliant! This should be the standard for all compact daily drivers. |
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
great job noel! wonder if the +6lbs(+500 ca) would be suffice?
Great "how to" pics but i dont understand why you would go to all that trouble just to put in a different battery
Is about to 'SeaYa' later
Is that the B106C from NST?
#8 | |
Is it for everyone? I don't know, probably not. Could you benefit from it? I believe so. |
H8R
How much does this new battery weigh?
nice writeup, very cool bracket they supply.. i simply laid mine on its side and shortened the stock "j bolts" to accept the new height :D
#11 | |||
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
This is the 11lb, B14115, Braille from NST! This battery is about 25lbs lighter than the OEM battery and should work for 99% of Yaris owners out there. You may also be able to get away with the 9lb if you don't plan on doing any stereo mods, and live in a warm weather state such as CA, TX, or FL year round. MORE INFO --> http://www.yarisworld.com/forums/showthread.php?t=13261
50 gallons of gas, or a 9lb battery ? ;)
I plan to do this mod but only after its time to replace my original battery. Just like how i plan to get rims after its time to replace my factory tires. I dont want to waste what is already good until its time to change. It helps justify the cost. A normal decent battery cost close to 100 so little more you get a better one.
#14 | |
#15 | |
![]() Drives: '91 Hilux, '91 Cervo Mode Join Date: Nov 2008
Anyway, cool writeup and good pics, nice work! |
And the screws are even SELF TAPING screws. Can't get much easier!!!
I used to have 1700 posts
wow that is way smaller than i thought it would be
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I just LOL every time I look at that battery! So tiny!
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 07:22 PM |
| Megan Coilover install DIY | kapo | DIY / Maintenance / Service | 5 | 09-24-2007 07:20 PM |
| DIY Sedan Spoiler Install Interest? | Kaotic Lazagna | DIY / Maintenance / Service | 28 | 09-11-2007 11:02 PM |
