![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
If you're like me and keep fueling even AFTER the gas pumper clicks that its full, yeah you'll get more miles on that first bar.
#2 | |
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
Also, bars are a rough indication of gas usage, but not totally accurate. |
My cap says tighten 1-click or check engine light may come on; EVAP leak.
![]() Drives: 08 Sedan Join Date: Feb 2009
The reason for not overfilling the tank after the auto-shutoff is due to getting liquid into your EVAP canister(s)... Those are expensive and only suppose to see vapor... but it's like a 10% chance you'll end up screwing the canister up one fill-up... not a big risk and you won't see it happen very often.
I don't fill beyond the auto-shutoff.... |
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
About 80 on the first bar, 70 second, and about 60 for the next few. I'm at the bar that tops out right at half a tank and I've went about 250+ miles so far...about 90% highway
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
I had one of those gas pumps that took 20 minutes + to fill the tank, but the bonus was that the tank gets wayyy topped off. I mean, you could see the gas inside the filler, that's how full it was.
It paid off, too, as I saw my record MPB. I got 112 off of the first bar (no joke), and was at 166 when it went down again. |
![]() Drives: 09 Yaris Sedan AT Join Date: Jul 2009
I got 82 on my first bar today! This is the first tank that I have filled. I consider a tank to be from full (pump click +to the next dollar) until the last bar starts to blink.
#8 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
I think the bars aren't all the same because the gas tank is not a perfect cube. For me:
First bar: 70-90 Second bar: 117-135 Third bar: 170-200 Fourth bar: 210-250 I generally fill up at half tank, but I've reached a "quarter" tank left at 335. *numbers are what is shown on the trip meter, not of individual miles per bar. If you want that, do the math. LOL. |
#10 | |
#11 | |
Ok, time to dumb it down a bit... the CEL comes on for more than just the gas cap being off... or loose. When the ECM goes into self-check it will run the evap system... if the pressures/volts do not fall within a specified range then the CEL will trip. The gas cap not being installed or being loose has nothing to do with the evap canister... which can become soaked with fuel when topping off. This also has the potential to trip the CEL. Odds? Probably 1 in a million (est) cars will end up having to prematurely replace the canister due to overfilling. Lesson? Read the entire post before commenting... and don't top off your tank... that extra squirt or 2 is not worth the cost of a new evap canister. |
#12 | ||||||
Fuel filler pipe and vent has nothing to do with the cansiter, vent and purge solenoids, or EVAP hoses and lines. When you're filling the tank the filler tube and vent go straight into the tank, they don't spill over to other components. Most filler pipes/hoses now have the vent hose built within the filler hose itself, older designs had the vent hose opening up near the top of the filler pipe, but the vent hose still dumped into the fuel tank, about 2-3 inches from the filler hose inlet at the tank. Quote:
If overfilling ruined the EVAP system then I guess there would be warnings about never parking a vehicle on a slope. Quote:
Canisters get damaged while the car is running, running improperly and a faulty EVAP system, has nothing to do with topping off a fuel tank. |
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 09:54 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| c one motorsport performance bars | badhabitz | Performance Modifications | 17 | 08-23-2006 10:31 PM |
