Old 02-11-2009, 11:58 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
One thing that may help is "the big 3". This is a mod which is very popular on other car audio forums. If you google it there are several tutorials. The bottom line is it greatly improves your grounding system. If your gounding system is a bottleneck, your system does not sound its best. Some also claim it takes away some of the stress on the overall electrical system.
If you look at the wire that connects the chassis to the negative terminal of the battery it is very small. I only upgraded the ground wire from the negative terminal to the chassis and the throttle response improved.
If you just want to do the "Big 1", get approx a 6-8" run of flexible 4 gauge or 0 gauge power cable(get it from www.knukonceptz.com). Make sure it is nice and flexible. Get two ring terminals(Again from Knu) that use little allen screws to tighten them down. This way you can adjust if it is too short or long. Do not remove the stock wire, just add the additional grounding wire to the stock location. Another thing you may want to consider is some light sanding of the chassis where the ground wire connects. There is paint and you should be in contact with the metal itself.
fuji is offline   Reply With Quote
Old 02-12-2009, 09:36 PM   #2
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Ok, i am back. I have been busy and haven't logged in.
anybody know the maximum mounting depth in the door panesl? WOuld lets say 71mm be too deep??
Fantastic idea, thank you. I will do that. Just add a few more 4 or 2 gauge cables to the grounding system. Thank you very much.
Originally Posted by wsladaritz
I'm running two amps also. A 4 channel for my speakers and a mono for my sub. Adds u to about 1200 or 1300 watts I believe. Got a yellow top battery and a 2 farad cap on my mono amp. My lights still dim just a little bit sometimes... The water line is on the right side of the fire wall... I think that is where I pushed my power wire through. I used the stock speaker wires. Cut them behind the radio, added speaker wire to and from the amp and back to that same spot. I think it would be an unnecessary pain to try to run new wires through the doors. Go check crutchfield for fitting on the speakers. Good luck with your install man! And welcome to YARISWORLD!
Thanks for that. I realised that there is a space under teh rear seat, is that where you have your amp placed?
Thanks for the warm welcome. I will post up photos of the install once i take delivery of the car. I am just acquiring my audio gear now.
I got a
-alpine CDA-9886 head unit
-eaudio 480ab 4 channel amp (no rear speaker, but 200+ RMS / channel bridged)
-Sub still looking. Looking for a SQ sub.
-Components still looking.. any suggestions? I heard the focal 165 krx2's and they sound very nice.
I live in Japan, and I usually buy off Ebay or Amazon as its cheaper, than locally. Anybody here know where else I can buy speakers? There isn't much Rainbow, Focal stuff on Ebay that will ship to Japan for a reasonable amount.
Thanks guys!
FEINT is offline   Reply With Quote
Old 02-17-2009, 08:18 PM   #3
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
I think the below might be better than an ebay grounding kit. I will probably due this instead.
I am trying to stay away from installing a new amp. I was really hoping to run what I have off the stock electrical system. I will give it a go, if I can't, will need to get a Yellow top.
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
battery power question TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 22 12-05-2008 08:37 PM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
