Audio Junky
The truth about caps
The following is taken from a PDF file I have. Richard Clark pretty much invented the trend of using the big capacitor for car stereo issues. Last I heard he worked for Monster Cable, I believe he worked for MTX at one point too. He completely denounces the worth of the audio cap in a stereo install for voltage purposes.
"This is a real world test that was measured by Richard Clark on a Audio Precision unit to portray what happens with a typical capacitor install. The main point for those who point out the obvious differences between the Red (cap installed) and yellow (cap not installed)…how much of a dB difference is .1-.4 volts in terms of music? And do you feel you are going to hear this within a car? On with the explaination: Dark Blue curve--- For our first test we played the system with the engine off and no cap. The result was the purple trace at the bottom. We played the system as loud as we could get it that seemed to produce no audible distortion. This was track 30 of the IASCA disc. It starts off with fairly low level sounds for the first 34 seconds. In order to insure the electrical system was stable we did not start the measurement until we were 20 seconds into the song. This means that our 0 starting point is :20 on the CD counter. The battery was able to maintain it's voltage just below 12.5 until the loud bass hits at 34 seconds (14 seconds into our chart) At this time it dropped to about 11.5 and had a few large variations due to the music. According to the computer calculations (third chart) the average voltage for this test was 11.7volts. This test was done as a baseline for the following tests. Yellow curve—no cap For this test the volume was left as it was for the baseline test. The engine was started. Notice that at low volume the alternator was able to maintain about 14 volts. When the loud music hit the voltage dropped to about 12.5 where it remained except for a few short moments where it actually climbed back to over 13.5 volts. The computer averaged calculations for the average voltage during the 100 seconds of this test was 12.973 volts. Red curve—cap added This test was identical to the previous test except the cap (15 farad type) was added 6 inches from the amp with 4 gauge wire—no relays or fuses. The red curve seems to overlay the yellow except that the actual peaks don’t rise as fast or as high during the brief quiet moments. I feel this would be due to the alternator having to recharge the cap. The voltage on loud passages hovered around 12.5 volts. The computer averaged calculations for this test show the average voltage to be 12.878 volts. I see no meaningful differences with or without the cap. I certainly don’t see the voltage sitting solid at 14 volts. One note I might add is that this was a two thousand watt system driven right to clipping and the average voltage stayed above 12.8 with a stock 80 amp alternator. Under these conditions the battery would never discharge! The green and light blue curves were done just for kicks while we had the system set up. In both these tests we turned the volume up until the system was very distorted. This placed a severe load on the alternator and caused the voltage to dip as low as 12 volts. The curves seem to follow each other so closely that unless you have a good monitor it is doubtful you can tell there are two curves. The average voltage for these two curves were both 12.277 and 12.295 volts. If this volume were sustained for very long periods of time this battery would discharge" |
![]() ![]() Drives: Yaris YRS Sedan Join Date: Sep 2006
Thought that'd be the case.
The quality of the Power AMPS internal stepup voltage SMPS is really what counts....i.e... High Current and Voltage stability. |
so the final word would be
do not use cap's and save your money for a bigger alternator.
It's like Richard Holdener of the audio world
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
but, the question would be, on a lower wattage system with a average cap where you were playing music with a consistent hit, that would require bursts of energy for the subs, would a cap be a bad idea? regardless of how it affects the alternator...because, the alternator WILL be taxed by lots of stereo goodies regardless of the alternator. i mean, you are still draining the battery.
i was under the impression all a cap was for was to reduce strain on your battery that causes headlights to dim as it sucks a large amount of amps with a quick bass note. a cap isnt meant to relive strain on the alternator, i thought it was meant to aliviate the battery. technically, no matter how powerfull the alternator and the battery(batteries?) the alt is still going to have to charge the batteries at some point, you are still using the energy when you are pushing your amps to clipping...no matter how many caps you have, that alt will still be taxed. i guess maybe i mis understood what manufacturers were claiming their caps could do. I always assumed that everyone understood a cap is for a faster harder hit of bass and would keep your battery alive longer and eliminate headlamp dimming. i guess i never heard of a company claiming their cap relived alternator strain.
Yarisomniac
Drives: 2009 5spd LB Join Date: Nov 2008
Yes - that would be my question - I used a cap in the past to stiffen the power supply to my amp(s) so my headlights wouldn't dim - not for any audio quality or dynamic range improvement - Is this still a valid use?
I am about to dump a new system into my 09 LB - and I do have an old 1 farad Lightning Audio CAP I was going to stick in there just for the heck of it inline with my new PDX5 amp |
Y4R1Z
I use a 2 farad cap for my subs. I only have it to keep my headlights from dimming on hard hits. And i severely abuse my system, almost all the time loud and angry and I almost never turn it off when I'm in the vehicle. I think it makes a difference for dimming lights. I never even thought it would or could improve the sound quality or loudness.
#8 | |
Audio Junky
Symptoms could include, weird rpm fluctuations, dash or headlight dimming, slower than normal starts when you turn on your car. There was another write up that was pretty good that I no longer find anymore, it showed the math behind the discharge of a cap... Basically It came down to a 1farad cap would only be able to power a 1000w amp for something like 1/10th of a second, and then its power is used up, and then becomes a drain on the system... That is where Richard Clark's article picks up. If a cap is being fully discharged, you've got bigger problems than a cap can fix. To answer the question about headlight dimming... yeah, a cap will make it appear that your head lights don't dim as much. The reason for that is because your lights won't be getting as bright. They will stay dimmer, longer, and thus you won't see as big of a fluctuation, because there will be a constant drain on your electrical system. |
#9 | |
Y4R1Z
#10 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Please explain the mechanics of phantom energy to me. Where does this drained energy go? (besides resistance) Finally, you should release these results to the thousands of stereo shops that recommend caps. Along with all those people winning stereo competitions. Oh the people making the caps will probably want to know too. I think I'm gonna stick with the millions of articles that say caps work, rather than the ONE that says they don't. |
#11 | |
Audio Junky
I have yet to see a single SPL vehicle at world finals run any caps. They have crazy sponsorships that allow them to pick them up for cost. There is a reason why they don't run them. All the non-believers can go to some actual car audio forums, elitecaraudio.com, and soundsolutionsaudio.com are two decent forums. Car shops make money on them, they make all their money on accessories.. Decks and speakers bring them almost no profit, its connectors, caps, and wiring that they get their profit from. Why stop selling a product that pays the lease on your building? there are also articles, RECENT ones that say likewise, Also, it takes NO education, not even a highschool diploma to open a audio shop, or to be the head installer. Try talking to an electrical engineer who has actually studied the science behind the problem, and is familiar with car electrical systems. If nothing else, adding a cap to the electrical system adds two more connection points which add resistance, and thats before you even add in the internal resistance of the cap itself. STORAGE MEANS NOTHING if the power plant can't keep up. Eventually the storage will run out. CAPS are storage... and a very small storage at that. Anything more than what is built into the amplifier is overkill, and will not help you at all unless you already have a power plant (alt) that can keep your storage (bat) 100% full 99.9% of the time already. If you fit that situation... then you won't have significant voltage drops at all, but you will still have very minor fluctuations (talking in the range of a tenth of a volt or less). In that situation... yes, a cap will help stabilize the voltage the way it is supposed to. But, is +/-.05v worth $100 or more per farad? People who have light dimming are most likely seeing dips of 1.5v or more already, just for refrence. For those who swear caps stopped their lights from dimming... did you have volt meters recording your voltage real time? Did you have light sensors watching the output of your lights... did you do A/B comparisons? If not, then admit that your "real world experience" is very possibly incorrect, and flawed with bias. I can't think of a better quote to describe this situation other than... "We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology." -Carl Sagan Last edited by talnlnky; 02-16-2009 at 02:31 PM. |
#12 | |
Audio Junky
From my experience, most people with subs in their cars have at one time or another taxed their electrical system too much. Most people who have subs fall in the category of 16-24 yr old males, and too often than not, try to put as big of an amplifier as they can in their car without doing any math to see if the car can handle it. For people running less than 600rms TOTAL in their car on a stock electrical, yeah, a cap probably won't hurt. But i've met more people who run more than 600rms to their sub(s) alone, than not. Oh yeah... and about your statement about caps not being a load on the system... why is it then that if you leave a cap for a day they lose their charge mysteriously... You charge something, and instantly its already losing its charge, even without using it. My statement remains, caps are the icing on the cake, upgrade the alt, all cables, and battery before even thinking about a cap. |
Secret Agent
Drives: 2008 Yaris Hatch Join Date: Feb 2009
To be honest, both of you are right.
A CAP will not make up for an overloaded electrical system. But a CAP can help a system that is close to its maximum capacity. And you need to match the CAP to the system requirements. You don't need a big CAP if you are running a modest system that is close to the alternators output. A 2 Farad CAP would be fine. If you are running big amps, you will need to upgrade the alternator. Most Alternators are around 80 amps max output. And you don't want to be pushing them at their max limit all the time. It will burn them out quicker. It is silly to put a bunch of big amps in your car, and spend all the money to upgrade the electrical system, when you could run less CLEANER power and still get good results. ALWAYS run the LEAST amount of power you need to get the job done. People with 2,000rms watts or more of amps in their cars are crazy. If you are doing SPL competitions, I can see it, but for the average music lover, 800-1,000rms total power is PLENTY. CAPS are only meant to provide a momentary surge of power to compensate for the amp drain hit during music. (Such as kick drums on the bass amp.) When the amp spikes, the CAP tries to fill the energy hit. The CAP has to be able to recover in between the spikes in order to continue to be useful. The alternator/battery is responsible for that task. MY experience has always been to go with speakers that have a high sensitivity rating ( greater than 90db at 1 watt ), very CLEAN amps, heavy gauge wiring, and the least amount of SUB to get the job done. A single 10" sub in the correct enclosure can almost always get the job done. 10's are better than 12's because 10's are more accurate. 12's require more box space, and more power, but they don't hit as hard as 10's. Also... use Dynamat! ( or any other good brand ) Most cars do not have adequate sound dampening. ( Yaris especially. ) AND.... if your total system wattage is around 800-1,000rms with a stock alternator... use a CAP. It will make a difference. If you are pushing over 1,000 watts, upgrade the alternator AND use a little larger CAP. If your alternator is strong, ( over 80 amps max output ) , and your system is less than 800rms watts, and you don't blast it at high volumes all the time, then you might not even need a CAP. Bottom line is: do you want clean powerful music to listen to in your car, or do you want other people to hear your "boom" from a half a block away? Totally different situations, that require totally different solutions. I'm not into the "boom". I like clean music IN the car.
www.sonicelectronix.com for all your mobile audio needs! |
#14 |
A capacitor is more cost effective than a high output alternator. Actually, that is an understatement. It isn't even close.
Also, most audiophiles don't go for SPL. I say a cap is still a great solution for someone who puts out slightly more wattage than his or her eggmobile can handle. |
#15 | |
Secret Agent
I think you might be confused. A CAP is no substitute for the correct alternator. A CAP does NOT create energy, it only "stores" it. The Alternator is the only thing that creates energy. Same thing with the battery, it only "stores" energy. And... a CAP is NOT a solution for a system that requires more energy than what the alternator can produce. A CAP smooths out the energy spikes. That's it. It can't do anything else. You can do a simple test on your own system: Start your car, and turn on the headlights. Now turn on your stereo system and crank it up to the normal max level you usually listen to it at. Raise the hood, and go to the battery in the engine compartment. Connect a voltmeter to the battery terminals. Raise the RPM's up to around 2,000. Read the voltmeter. You better see 14volts+. If you do, let it go back to idle. Check the voltage drop. It better stay at 13.8 or higher. It's better to measure the "current flow" and not the voltage, but the voltage test is simple. Anyone with a common multimeter can take a voltage reading. Keep in mind, if you live in a hot climate, and run your A/C all the time, then you also need to turn your A/C on when you do this test. An A/C system can pull alot of amps and put your total amp draw over your alternators limits, when used with your stereo system. A CAP is not going to fix an overloaded electrical system. It will only smooth out the energy spikes during music play. I still recommend using a CAP, especially if you run higher power / multi-amp setups, which most people do.
#16 |
So what if your headlights dim to 75% of their normal brightness every time your sub hits?
Say "get an alternator" and I'll throw something at you. I only need a CAP!
#17 | |
Secret Agent
With most compact cars, it's hard to find a good place to mount a second battery. Some people like those deep cycle yellow-top Optima batteries. I prefer the red-top Optima, but either way, those batteries aren't cheap!
#18 | |
Secret Agent
The CAP worked for you, so obviously you needed it.
| center caps for enkei rpf1s??? | andruboz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-05-2010 11:37 PM |
| How to put center caps on wheels w/o breaking them? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-09-2009 07:29 PM |
| FS: Stock LB wheels, tires, caps 2K mi, NorCal | JosephDoc | Items for Sale by private party | 1 | 09-20-2007 04:09 PM |
| Need Help on finding 15 inch Hub Caps | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 18 | 03-31-2007 02:12 PM |
| WANTED - Stock 15" 2007 Yaris HUB CAPS! | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-29-2006 08:09 PM |
