Old 02-13-2009, 05:46 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Does this "afterburner" work with the Yaris?
Here is the link http://www.jegs.com/i/Hot+Rod+Speed+...3505K/10002/-1
On the website says "Afterburner Flame Thrower kits will work on any carbureted, non-emission controlled vehicle"
Old 02-13-2009, 06:05 AM   #2
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
our engines are fuel injected, so answer is no
staypuft is offline   Reply With Quote
Old 02-13-2009, 06:36 AM   #3
Parmas
Parmas's Avatar
Can it be possible to make something similar for fuel injection cars?
Old 02-13-2009, 06:46 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
yes. you'll have to install a propane or butane bottle in the car
Old 02-13-2009, 07:37 AM   #5
Parmas
Parmas's Avatar
What about if you run rich and using the kit, will it produce the flame?
Here are some vids since we are in discussion..
http://www.youtube.com/watch?v=_VWcZ...eature=related
http://www.youtube.com/watch?v=38czG...eature=related
http://www.youtube.com/watch?v=n2iNg...eature=related
http://www.youtube.com/watch?v=tdTf1...eature=related
http://www.youtube.com/watch?v=sD21Hvlgv54
http://www.youtube.com/watch?v=81GPj...eature=related
Old 02-13-2009, 09:33 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
if you still have your cat installed, good chance it won't work
Old 02-13-2009, 10:00 AM   #7
Parmas
Parmas's Avatar
I intend to use it with a straight pipe exhaust without cat. The ecu is a gotech mfi standalone fully tunable.
The intension of use is only for pure car show meetings obviously not street use!
Old 02-13-2009, 11:23 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
ah
you could use just one coil and a sparkplug and do it pretty easily..
Old 02-13-2009, 09:42 AM   #9
elmo
WFO
elmo's Avatar
Drives: 2008 hb
maybe i'm just getting old but why would anyone want something like that ?
elmo is offline   Reply With Quote
Old 02-13-2009, 10:41 AM   #10
Benggolf2
Benggolf2's Avatar
Well, perhaps to impress by-standers and torch the fella tailgating you! Whoa!
Benggolf2
Old 02-13-2009, 11:49 AM   #11
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Don't laugh, benggolf, decades ago a buddy of mine torched a following vehicle... Night time, a guy pulls up behind him with high beams on. He reaches down and hits the switch, and only then did he see the flashing lights of the cop car in amongst the flames...
Old 02-13-2009, 11:52 AM   #12
staypuft
aka SDMF
staypuft's Avatar
owned lol
Old 02-13-2009, 12:21 PM   #13
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
DFA is offline   Reply With Quote
Old 02-13-2009, 04:57 PM   #14
Benggolf2
Benggolf2's Avatar
Nice to know it is an effective flame thrower!
Give a good reason to consider this mod. No kidding.
Anyone up to group buy or designing a "flame-thrower" kit for radical YW forum members?
Benggolf2
Old 02-13-2009, 03:45 PM   #15
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
1.) small bottle of nitrous oxide
2.) purge kit
3.) RC car glow plug
I have seen a setup using these three things set up just left of the exhaust. The guy, a wiring god, wired it somehow to burn after a high rev. Spent less than 100 bucks.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 02-13-2009, 04:14 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
2.) purge kit
gonna have to call BS on that one..
http://encyclopedia.airliquide.com/s...093A_AL_EN.pdf
non flammable gas.. you'd STILL need fuel added to it for it to "burn"
Old 02-13-2009, 06:48 PM   #17
thewifesyaris
Well it worked, I just thought it was neat that he used a 1.5 volt RC car glow plug. Otherwise I had no idea nor care to how the hell it worked.
Isn't oxygen considered a fuel, not too overwhelming intelligent when it comes to chemistry but I thought adding oxygen would make no2 flammable.
Two Yari on home!
Old 02-13-2009, 11:35 PM   #18
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
N2O adds oxygen to combustion
http://en.wikipedia.org/wiki/Nitrous_oxide
N2O is an oxidizer. At higher temperatures it breaks down and gives up it's oxygen atoms. By providing more oxygen, more fuel can be burned, providing more energy or power. I can see how N2O can add to the flames at the exhaust, but it would have to be added after the engine.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
