Old 12-23-2009, 01:26 AM   #1
90tsi
90tsi's Avatar
Drives: 09 yaris
this may sound out there but there was an article in turbo mag a year or 2 back and it had an equation that you could use. dont quote me exactly but if i remember right you could plug in displacement,horsepower goal, and a few other factors and it would get you a good estimate of what cc injector you needed.
90tsi is offline   Reply With Quote
Old 12-23-2009, 02:00 PM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Finally we decided what injectors will suit best and we chose the Siemens Deka 4 630cc.
These injectors flow 220 lbs/hr at 43.5 PSI ( 3 BAR ) and more at higher PSI! These units are low-impedance and require peak and hold injector drivers or additional resistors for saturation drivers. Despite the high flow rate, they are linear and controllable at low pulse widths compared to other extreme flow injectors! These injectors are sometimes referred to as 212lb/hr or 225lb/hr injectors
Any has experience on these?
Parmas is offline   Reply With Quote
Old 12-27-2009, 12:48 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
If I remember correctly, these injectors were pretty popular with WRX guys.
Old 12-29-2009, 02:06 PM   #4
Parmas
Parmas's Avatar
Well that's good news since that increase the probability of being ones of the very best racing injectors one could own.
I hope they are efficient as advertised as these will probably be a good indeed upgrade. Bye Bye tuning probs :)
Old 01-07-2010, 02:44 PM   #5
Parmas
Parmas's Avatar
Some pictures of the rear mounting. Sorry about the blured image but the camera sucks at close ups!
Old 01-13-2010, 11:56 AM   #6
Parmas
Parmas's Avatar
UPDATES:
UPGRADED INTERCOOLER HOSES TO SAMCO RED :)
SHOWING CUSTOM BLUE WATER HOSES ASWELL
TRD CAP
Old 01-13-2010, 01:48 PM   #7
cool, very colorful -- what throttle body is that?
Old 01-13-2010, 02:41 PM   #8
Parmas
Parmas's Avatar
Stock 1NZ one
What do you think about the rear mounting I posted before garm?
Old 01-27-2010, 01:40 AM   #9
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Sexy engine! You need a pink dip stick to set it off!
Old 01-27-2010, 04:39 AM   #10
Parmas
Parmas's Avatar
OR >>> Garm's Intake Mainfold
I'm waiting . . .
BTW just found this on my pc > http://www.youtube.com/watch?v=u0wage2LBdM
Old 02-12-2010, 11:27 AM   #11
Parmas
Parmas's Avatar
This week we installed Siemens Deka 4 630cc injectors. Since the Siemens housing length is slightly different from original toyota injectors they needed to be "modified" to match the fuel rail.
Now needs tuning from scratch, I hope it makes real power with these on
Old 02-12-2010, 12:37 PM   #12
ooh man can't wait for new results!! I have great hopes for this project!
Old 02-12-2010, 02:51 PM   #13
Parmas
Parmas's Avatar
My tuner just called in to tell that tomorrow will trial the car for some drag races. I am expecting 16psi or more boost with better AFR numbers than the previous tune.
Guess what? ..... if all goes well I think I will be the one to trial the Gude Performance Head package on our 1NZ. I already send him an e-mail to get some more details on cams....
Stay tuned!
Old 02-12-2010, 06:29 PM   #14
You're drag racing tomorrow? or tuning tomorrow, or both... ?
Old 02-13-2010, 01:29 AM   #15
Parmas
Parmas's Avatar
Both :) Since we tune specifically on drag road for a precise and realtime tuning...
Old 02-13-2010, 02:27 AM   #16
oh "street tuning", gotcha.
Old 02-28-2010, 03:38 AM   #17
Parmas
Parmas's Avatar
Some bad news....
Yesterday we done a compression test since we are still having trouble idle and slow runing the engine. Well it result that 2 cyclinders are loosing compression and probably some valves not sealing properly...
There is also a problem to convert the engine with the authorities (due to some changes in law) since there is a fine difference due to bigger displacement (probably within $2000 range ) So we are now intending to modify the 2NZFE 1.3L engine block to match the 1NZFE rods and in the meantime solving aswell the problem of the compression. We have to measure all the necessary points of the block in order to make this happen....
This will cost lots of money & time and since I am out of cash it will be a while to update my status....
Old 02-28-2010, 11:28 AM   #18
aw, so sorry to hear this. Do you think the motor came to you with these problems?
Is this your first compression test on it???
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
