Old 03-09-2011, 09:04 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If it's still reading 14-15 with the engine off, either your software is clamping the sensor or it's gone bad.
Old 03-10-2011, 11:59 AM   #2
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
mine is 4-5 inches from my turbo in my wrx, its worked for 2 years, i believe i need a new sensor now.
as for the sensor reading when the car is off that is normal. the exhaust the piping is that afr, if you leave it on it should slowly slowly dissipate.
free air calibration requires you to remove the sensor from the down pipe in fresh air.
can always try replacing the sensor, i believe most use the 5 or 7 wire bosch. can get them at a decent price mostly.
Scubaru Steve is offline   Reply With Quote
Old 03-12-2011, 01:49 PM   #3
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Thanks for the suggestions.
I tried the free air calibration and didn't change at all. Contacted Haltech directly and he needed a log file of the AFR reading vs Sensor voltage. After he send a reply that from the log it seems that the sensor needs replacement!
I hope the next one will at least be good for one year and not 2 months!
In the meantime I am trying to solve the last issues and installations which are:
- Oil leak from the turbo compressor discharge area
- Need new oil gauges as I have issues with them
- Installation of the NST torque damper
- Installation of the NST crank pulley
- And finally off to the dyno and hope will be ok for long time!
The main thing that is making me nervous is the oil leak from the turbo to the discharge/boost piping. I was thinking that the turbo seals were gone but I went to a Garret distrubtor and checked shaft play and seems fine. He said that for turbos it is normal to have a slight oil leak from the discharge area but I am not sure about it after I read this http://www.turbobygarrett.com/turbob...timization.pdf
11 Point Checklist for Turbo Best Performance and Efficiency.
1. Application Information – target horsepower, intended use of vehicle, etc.
- Street / Drag racing. Target Hp 300Hp
2. Air filter sizing - determine size for application needs
- Air filter piping is the same size of the inlet compressor housing
3. Oil Supply - restrictor for ball-bearing turbo
- Ball bearing turbos use 1mm restrictor ( which I have it installed recently )
4. Oil Drain – proper size and routing
- The Drain size seems enough visually but I am not sure how much is the inner diameter. Although I have a suspect in this case.... Since the turbo is behind I can only touch and feel the area and cannot see it with the engine on the car. I am sure I felt a short 90 degree angle fitting exactly after the turbo fitting and it could be there is a bottle neck there. I am trying to re-route the drain to a straight line as possible
5. Water Lines - set up for greatest thermal siphon effect
- Siphone effect means water IN must be connected to lower level than Water Out if (I read well the document in the link). I am using the water lines that were connected to the Idle control motor but I didn't know which is IN or OUT ?
6. Charge Tubing – determine diameter for application needs
- Charge Tubing is 2" which is the same size of the charge outlet of the turbo. I don't see an issue about that.
7. Charge-Air-Cooler - determine core size for application needs, design
manifolds for optimal flow, mount for durability
- Intercooler is a little big but I prefer to have some lag than having high intake temps. Lag should be gone after I increase more boost.
8. BOV – VTA for MAP engines and by-pass for MAF engines
- HKS SSQV BOV seems fine for me
9. Wastegate – connect signal line to compressor outlet, smooth transition to
external wastegate
- Using internal wastegate, no issues with that
10. System Testing – pressurize system to check for leakage, periodically check
clamp tightness and the condition of couplers
- Here is the problem
11. System Monitoring – proper gauges/sensors to monitor engine for optimal
performance and component durability
- A turbo speed gauge. Is it really needed?
Old 03-27-2011, 05:51 AM   #4
Parmas
Parmas's Avatar
I got the turbo checked by a specialist regarding the compressor oil leak and he said it is fine and there is no play with the shafts and it must be something with the drain.
So I am arranging the drain setup to a straight line and a bigger o/d pipe to try to solve this forever.
In the meantime I done some works while the turbo and manifold are out.
Will post some pics of the drain new setup when it is ready
Old 03-27-2011, 06:31 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
quick question.. i know the reasoning behind the exhuast wrap, but is it nessissary on the yaris for safty or are you just doing it for added performance?
Old 03-27-2011, 12:53 PM   #6
Parmas
Parmas's Avatar
The reason is both.
1. Prevent heat to damage or wear any parts like gear cables, hydraulic tubing and any other thing in its vicinity. (Especially for our small engine bay this is one to take care of) . I already replaced 2 gear cables because of this btw!
2. With the Thermal barrier paint plus the Exhaust wrap I am hoping to obtain lower engine bay temps to at least 10C lower as advertised. Also with the wrapping you are keeping the exhaust gases as hot as possible. The hotter the gases, the better they flow and with all going to the Turbo you might sense a better or earlier spool up.
Old 03-31-2011, 02:32 AM   #7
Parmas
Parmas's Avatar
Finally installed the NST crank pulley set. No issues yet....
Old 03-31-2011, 03:44 PM   #8
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
And there won't be.
Yoda is offline   Reply With Quote
Old 04-01-2011, 06:24 AM   #9
Parmas
Parmas's Avatar
Originally Posted by Yoda View Post
And there won't be.
Today I had some time to fix the power steering and alternator belt in place. With the power steering belt had no issues at all.
Although with the Alternator Belt I had issues with it. I have all 3 pulley NST set and the belt matches perfectly the alternator pulley while in the crank pulley it is a little bit tighter. Infact the belt curves through the edges of the crank pulley. Pushing it with my finger with some force it sits ok while on the alternator pulley it sits easy.
Is there anyone having this issue?
Could the belt slip if I try to run it like this?
Old 04-01-2011, 09:01 AM   #10
Bluevitz-rs
maybe a picture might clear this up better.
Old 04-01-2011, 03:12 PM   #11
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I have my aem wideband in the same location as yours. Did U find out why yours stopped working? Mine is working good. But the stock sensor that was located right next to it is fried. Mabe heat? I dont know. I had to lengthen the wiring on the stock sensor so it would reach. Engine compartment looks sweet!
pimp my yaris is offline   Reply With Quote
Old 04-01-2011, 03:29 PM   #12
cdydjded
Drives: Yaris LB Turbo
Do you need a replacement o2 sensor? I have 2 extra ones....
cdydjded is offline   Reply With Quote
Old 04-01-2011, 04:58 PM   #13
Parmas
Parmas's Avatar
To blue vitz - I will take one tomorrow. Probably I have to remove it again and modify the width of the pulley where the belt fits.
As regarding to the sensor, AEM and any brand that make widebands recommend at least 14 inch down from the turbo. So by rule mine is located wrong and I am thinking of doing it the right way they recommend.
To cdydjded - I already have 2 sensors in stock ready to install but thanks!
Old 04-02-2011, 04:50 PM   #14
Parmas
Parmas's Avatar
I couldn't get a good picture for you to review although I managed to fix the pulley by machining a bit from one side. Now the belts hook fine with no problems
Old 04-02-2011, 06:39 PM   #15
Bluevitz-rs
Old 04-03-2011, 04:15 PM   #16
Parmas
Parmas's Avatar
Drain fixed to a straight line with bigger inner tubing. Wrapped the tube with titanium since it is passing through lots of heat there.
Sorry but picture was taken by my mobile..
Old 04-03-2011, 06:53 PM   #17
johnny_vitz
Drives: 2005 Toyota Echo
Have you put the manifold back on since the wrap went on? It looks like you might have a hell of a time trying to get a couple of the bolts done up
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-04-2011, 03:40 AM   #18
Parmas
Parmas's Avatar
Yes infact the middle bolt of the manifold flange needed to be replaced to a shorter one because of the drain going down exactly infront. Took me about 10min to fix that only bolt in due to lack of space.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
