Old 07-22-2009, 02:10 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by dg4rez View Post
im running a 300/2 JL amp to them, they are rated peak 400watts per set, (200 each side)
RMS 200watts per set / 100watts per side.
and they are by far the loudest / clearest sound you will get out of a 6.5 speaker
There is always something better... I know of some 6.5's that can out-displace most 8" speakers (not 8" subs... but speakers).
Focal are generally pretty good speakers, I almost went with some focals back in 03... but decided against them due to the very bright tweeters they usually have.
Old 07-22-2009, 10:17 PM   #2
dg4rez
Gas Saver
Drives: Toyota Yaris Hatchback
Send a message via AIM to dg4rez
with my job, im in an out of cars all day, a lot of them with hooked up systems. And I've parked hundreds of SEMA, and CES cars. like JL's, RF's etc cars/trucks. And my focals are by far the most i've heard scream. But you have to have a sub with them, they dont have much bass. they are all mids and highs. and yes, the tweeters are insainely loud.
dg4rez is offline   Reply With Quote
Old 03-03-2009, 06:39 PM   #3
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
what did you pay for them if i may ask ?
pennyracer is offline   Reply With Quote
Old 03-04-2009, 03:58 AM   #4
dg4rez
Gas Saver
deck - 300
W7 - 550
focals - 440ish or something like that
JL 300/2 - 200ish
Alpine 800 - alot cause I bought with custom install (but around 400ish)
Old 07-19-2009, 11:50 PM   #5
pennyracer
boydstir
pennyracer's Avatar
thnak i got some 3 way focals for my doors they sound very nice plus i had the doors worked to the max with raamatt and dynamat foam sound barior also
Old 07-20-2009, 08:31 PM   #6
dg4rez
Gas Saver
looks clean. you custom make that case for it?
Old 07-20-2009, 09:45 PM   #7
pennyracer
boydstir
pennyracer's Avatar
yes they are hand made custom pods . the sound is awsome now i have to make my new sub floor to hold 3 10" subs im running two right now this complete sub floor is for sale if you are looking for some serious good sounding bass without losing any cargo space $350.00 without the arc audio 10" or $500.00 with the subs included
Old 07-22-2009, 04:26 AM   #8
nth09
Drives: vios
updated video:
what is the material of that black piece of glossy layer on your sub? Acrylic?
nth09 is offline   Reply With Quote
Old 07-22-2009, 10:15 PM   #9
dg4rez
Gas Saver
no idea, its a factory spec box, from JL themselfs.
Old 07-22-2009, 03:15 PM   #10
pennyracer
boydstir
pennyracer's Avatar
i have to say the tweeter is a bit bright with my focals but the cross over has tree settings for that in my case with running the mesh covers it did help cut down on the brightness a bit but going with the 3 way set i say much better than a two way setup glad i went the route i did and doing the doors full tilt double layer raamatt and dynamat foam outer layer is awsome but im still not done more to come thats a promise
w7 focal k2p k2
